Originally Posted by ***Deimos***
On the top graph, I first ran without modifying clocks (BIOS values), then clock to 425/950 to simulate throttling.
Once again, I know about force-perf-level, or setting all clocks same in rivatuner, or setting all clocks same in BIOS. The same thing happens regardless. Either the card runs at full performance, or it runs at nearly identical performance to GPU=300Mhz (where would it get this clock speed from?), even though rivatuner continuously shows the same high overclock (ie 410), or terrible artifacts. When clocks are different, and there is no force-perf level, artifacts ALWAYS correspond to it switching to 300Mhz, and sometimes to 400 (using your bios).
I would be happy to let 425/950 go. I have nearly come full circle, and have re-investiaged the famous 6800/NF3 connection (yeah, I have NF3). So, I re-enabled FAST WRITES in mobo BIOS. Now, it might be just a coincidence, but anything north of 370Mhz, causes stuttering, pausing, blank screen, and yes even artifacts. However, the strange thing is, when 3DMark05 run for first time (starting from 2D clock), it will blank screen/pause resume, then pause again etc... when you quit test, it clocks up to 410 (even though you're just on the desktop). Quick subsequent run (before it throttles back down), it doesnt pause/blank at the very beginning.. still happens later on though. But rivatuner shows that higher clock was used for the first little while until it pause/blank and there is corresponding throttle to either low-power 3D or 2D.
I went over all the 6800/NF3 "solutions" again to make sure I didn't miss something: AGPx4, AGP=55, AGP=75, sideband=off, user mipmap=off, blitting, aperature=32, aperature=512 (normally 256), lower RAM speed 10%, CPU at stock, CPU @ 800Mhz, loosen all RAM timings, ...
Only thing that "works" is fast-writes = off. However, I think its only lowering the occurance of the problem. Quite similar symptoms show up, but much more rarely with fast-writes off. So the only way to get consistenly 3D clocks is 370/740 with fast writes off (370+ and/or 800+ will sporadically cause throttling)
EDIT: I'm already on 4th power supply!! And, I'm still trying to get this card working on my brother's computer.. last time just installing the card messed up windows and his ati drivers really bad.. he had to reinstall windows :(
