that's not actually what the delta clock is.
basically 7 series cards have 4 different clocks, geometric core clock, shader core clock, ROP core clock and memory clock.
the shader and ROP run in 3d at whatever you clock them to in coolbits etc. (though they only have speedbumps every 27mhz.)
the geometric core clock is the one thats affected by the delta, it's basically the above clocks + the delta value. the geometric core clock doesnt clock in 27 mhz steps though, which is why you will see a minor increase in speeds even without going up in 27mhz steps. :)
