That's why I'm a Hipro5 fan.Quote:
:toast:
I wasn't being rude my man. Was more or less poking fun.
Wow man you keep coming back and impressing me even more! I hope you'll break 60k soon enough! :D
Thanks M8.....:)Quote:
Originally Posted by Mr. Tinker
Originally Posted by Hell-Fire
I know that......I have puted a smile in the end of the sentense and not a ( :mad: )......:) :toast:
I realy looking forward too this..:)Quote:
My xtx was dooing 953/963 before but now it only can doo 900/960... i realy hope some volt can bring it back too 950+++on the core in my cascade :)
Imaging my fx 60 @ 3650 and 975/970 on xtx in 05 :D
Your gonna need some other holes in that ;)Quote:
Originally Posted by GoriLLakoS
I was looking over the overclockers dictionary and under hardcore they had this guy named hipro, hurry up and show us these mods!!! ;) :D :toast:
Really great work as always hirpo... you truly a need in "our world"
@ Overklokk
looks like your chip is degrading or power management system does
hope evertthing is ok tho
I hope it wil be better with more volt :)Quote:
Originally Posted by \carting_freak
Preparing for som 01 runs right now and hope the picture from master Hipro is here soon :)
testet one run with only air and 735/830 on my xtx and 3875 on FX57 (cascade)and godt 48,5k :)
This is realy great Hipro...thank you....Hardmods is exactly what i need right now. i actely also found out the thing about the mem, but needed to test it on a 3rd XTX before i was sure:) you are the best:toast:
Originally Posted by SIOUX
You're welcome......:) :toast:
I have the photos BUT I forgot them on my digicam in my working place with all that benching today.......I'll post them tommorow........;)
EDIT: I think Gorillakos took some photos today just for example......IF he is in now.....
I don't have them....they weren't good and i deleted them....:(
@GHZ...i know about the holes...:D i am working on new cans right now....but it's too difficult to make a good solid one for Vga's...:D
:slobber: :D
Can't wait them :)
I think you deserve some title other than Legend as the wealth of knowledge and input you have betrothed to the community over the years is unmeasureable.
Thank you Hell-Fire.....:) :toast:Quote:
hipro whene are u gone show us the hardmod :D so wee can begin benching sub-zero to :p:
NOW.......This is "almost" my maxed out frequency as for this VGA after the mods......;)
http://www.thelab.gr/images/Hipro5/D...7bench_png.png
It was done with the DOTHAN at only 2970MHz due to finished LN2.......:(
When the VGA showed -84*C on ATItool, it started artifacting so I lowered the cascade's temp......
Some updates about the mods.......NOT good photos though but if anyone could upload some good pics, I could redo them.......:)
http://www.thelab.gr/images/Hipro5/D...re_Mod_jpg.jpg
http://www.thelab.gr/images/Hipro5/D..._Mod_2_jpg.jpg
http://www.thelab.gr/images/Hipro5/D..._Mod_3_jpg.jpg
http://www.thelab.gr/images/Hipro5/D...CI_Mod_jpg.jpg
You will need 2 x 50KOhms trimmer for the mods(10KOmhs was not good)....
You also have to find YOUR OWN voltage on the VGA......
Mine works with no more than 1.76VCore.......;)
VDDCI was preset at 1.75Volts during boot......I mean trimm the trimmer at it's MAXED Ohmage, then solder it and then trimm it at 1.75Volts.......DON'T change after that the VDDCI within ATItool........You'll not gain much if any - test it a bit though.....;)
Trimm the VCore at 1.35Volts MAX when VGA boots or else it wont boot.......If it doesn't boot, try to trimm it back.....Measure and change the VCore within ATItool for more.......FIND your MAX VCore......:)
Fire up your cascade AFTER you are into Windows and AFTER you have given more VCore and a bit higher frequency on Core and Rams.....OR else artifacts(cold bug) will hit you......When your cascade starts to lowering temp( @ -50*C), give your VGA more frequency on core and on rams......FIND your MAX lower temp on your cascade depending on you VGA........;)
EDIT: If you take a good look at the first and second photo, you'll see that I have replaced one tiny resistor(500Ohms) coz the mods were done on the VGA as is now and not on the table......BE CAREFULL about these tiny parts.....They are very delicate.........
thank you hipro.
i've been waiting for this for a long time
here's a pic of my last setup for fun :D
edit. would you know if this is possible to test with a pencil mod?
http://flytek.sa3doc.co.za/screens/atiln2.jpg
Well Hipro, those pics are a little bit blurred.
I'm unable to get the right point of the vcore mod.
Thanks a lot for sharing.
Yes I know......That digital zoom sucks........If anyone could upload some nice pics of the area on the VGA, I could redo them so as to be OK......:)Quote:
Originally Posted by Waxman
il get them now brb ;)
here thy are , the server whase down ?
http://i3.photobucket.com/albums/y90...r/DSC07252.jpg
http://i3.photobucket.com/albums/y90...r/DSC07254.jpg
here is the cooling for the moment then wc en then phase ;)
http://i3.photobucket.com/albums/y90...r/DSC07247.jpg
hope it helps u hipro , dont tell me about the pcb color i have paint it ^^
attached :)
Now, THAT'S a photo!........:D :toast:Quote:
Originally Posted by flytek
Here you go......
http://www.thelab.gr/images/Hipro5/D..._Mod_4_jpg.jpg
Any chance to picture the VDDCI place too?........
Thanks a lot hipro.
Will that mod help on water or it's only for phase users?
