Thanks for that, but i thought that (from seeing amd dual.c) when you run dual super pi you have to set the seperate affinity so one core is allocated to one super pi, which should give the same results as if you were running single core? (maybe dual core a bit slower because having to run windows too)Quote:
Originally Posted by VictorWang
Also, what temps are these hitting, under what cooling?
