stil a nublar I guess but I did get a higher score in 2k1 without explorer loaded but that was with aditional reg tweaking so idk guess someone has to bench it exactly same settings with and without explorer and atm my 2k1 partition is a mess :(
Just did a compare of without and with LOD, gains are sweet, must be at least 2k plus, loving the nature gainage especially.
Sweet guide :)
Thanks lawrywild for the info. Much appreciated :)
http://img108.imageshack.us/img108/2...orer0iq.th.jpgQuote:
A minor compare @ 01SE :S
EDIT: Notice CPU freq..
nps :thumbsup:Quote:
Originally Posted by Bennah
:confused: what exactly am I looking at? yes I see 3200mhz but what's your point?Quote:
Originally Posted by M.Beier
LarryWild... damn yeah now I'm reading your sig I remember I hate you :p:
Your 6800le scores where always way to high for me to beat but I'm still pretty close for an asrock/3200+ combo
Got some tips for me besides upgrading hw :stick:
Edit: orb submission under me_Westmaas almost forgot :slap:
lol what cooling are you using?
my tip is get air as cold as possible..
all my 6800le scores were on my 24/7 xp partition coz I didn't have to time to optimize a partition and stuff, could have got higher if i'd bothered..
My point being, I've done quite a bit tweaking :) - I belive explorer has to be on - except AM3. - In fact I belive its a 300mark lower score in 01SE by turning off explorer.exe... :S
cpu is wc now but very entry level kit ( koolance pc3-720 with zalman wb3 gold ) card is with zalman 700cu. Your clocks are amazing for air, what mods did you do on the card? And I bet I would be allot closer if my cpu wasn't crapping out at 2.65ghz and if I had a better mobo then the asrock dual.
on topic: M.Beier I benched 01 also with exact same settings with and without explorer loaded and from 3 runs I got 2 higher one's without explorer. Was within the 100/150 points margin and damn 01 is a :banana::banana::banana::banana::banana: to try to compare diffrents tweaks because off natural score variations. I spend days figuring out what lod was the best for my particular setup and it still gives me nightmares.
if you have freash install, no wall and other visual things, killing explorer.exe allways gets you worse result, 3dmark, superpi...
that's with my experience. On the other hand, if you have a "nonbench" install with big pix as wall, killing explorer helps.
I stand correct by so many people saying it's better to have it loaded. Would love for someone to explain why though? Explorer.exe doesn't perform any tasks while benching wich influence the score if I'm not mistaken?
zbogorgon it would be better to not kill explorer but to remove desktop wallpaper and any visuals ( eg clasic theme ) right?
Indeed, kill wallpaper & especially screensaver - screensaver is a killer :S
- Watch out with using service tweaks, the wrong one being disabled aint nice :P
mods? meh... if you call a bios mod to 1.3v a mod then...Quote:
Originally Posted by MartianInvader
I did attach a cpu cooler to mine, but can't find post where i showed pics, I'll take a further look now
Is booting in diagnostic mode not a quick and easy way to get rid off allot off crap you don't need? I do that, and disable any services I think I don't need from there. Lol it's a :banana::banana::banana::banana::banana: though I forgot to turn windows sound on and I spend an hour installing drivers and another sc before I looked in the services if I didn't forget something
Lol I have mine flashed to 1.5v for months now already ( game 450/900 )... Card burns up without a fan blowing over the pcb but with the fan it's still alive and kicking :banana:Quote:
1.5v ewww...
I have a feeling that card is going to go up in smoke soon... :stick:
Alive and kicking for months already...
yeh but those vregs... hmm i'd be worried...
Lol check the le blackout thread I made a post there ;)
Here you go
http://www.xtremesystems.org/forums/...ghlight=6800le
oops meant to post this; http://www.xtremesystems.org/forums/...95&postcount=1
but you can read other thing aswell if u want..
I notice that the system test ( ll/lh/cl ) benefit from the intel allot ;)Quote:
Nature you still beat me with 15fps though we got almost identical clocks ( +5 core for me, +30 ram for you )... mhm 30mhz isn't that much :confused:
You got any pics left off your custom cooling solution?
Edit: lol I got the leadtek to
no idea if its useful but im usin it :P
just set in teh boot.ini /nodebug
also tweak teh services down 2 teh max
#10 disables windows file protection, then you just delete teh OS2 and POSIX subsystems, without having to disable them, though that is preferable.
Oops missed that there was some info missing.
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Contro l\SessionManager\SubSystems]
"Optional"
->Clear completely to disable POSIX and OS2 subsystems, always welcome
IIRC that's what you mean Perry?
You can kill as many svchost.exe as you want, and if you end up with the "The system will reboot in 54-53-52", go to Start->Run (or press WinKey+R) and type "shutdown -a" without the "s
Always try to end explorer last (in case you want to end it) because Winkeys and Run won't work either :D
