ya but not stable at 2320... just enough for a sisoft cpu benchmark... 100% stable at 2211
edit: opps had to add 1000 to the top post. :p
Well I just bought one of these chips for a customer's rig.... I was testing it out to see how it could OC w/ an SLK-800A + tornado, and @ 1.975v I could get into the bios fine @ 195x12.5=2437mhz. Gonna try for higher w/ more voltage ;) Then imma install OS and get to some windows oc'ing ;)
These puppies are SUPAFAST! :)
Sys, sounds good. But I decided to try and get there with less voltage if possible, so I went with the 2100+ instead.
it's an JUICB 1700 at 2,325 V on a KD7. 2550 was the max I reached
http://people.freenet.de/benches/temp.jpg
:D
Wow! There's somebody who isn't afraid to feed a chip some real volts! :toast:Quote:
:D
Nice oc!
BTW, welcome to Xtreme! :)
look at temps! 2550 with 2,3V and that temps sucks, i can reach 2500 with -7C h20 and 2,1V with my JIUHB 0302 9 green;)Quote:
Nice oc!
Sounds super, gonna phone a guy tomorrow and see if he has any JIUHB 0302 left in stock, if he has ill buy one for me :)
awesome just got my juihb 0302 in today
runs @ 2003 or 2006 but my hsf craps out, its a stock amd one
volts kept stock as well
:smileysex :banana: :D
i ordered one this morning... ill report back how it does in my prometiea when i get it!
Hi to all OC addicts
My first post here :)
Few days ago I managed to burn my 1700+ AIUGA @ 2000 Mhz, my pump wasnt running for half an hour...
So i bought 1700+ JIUHB 0302 and with my setup I can reach 2400 Mhz but isnt 100% stable .
I think 2350 will be enough for me :D
I can't go closer to 2400 becouse of my stupid board
Elite ECS K7S5A (Vcore,VDimm,Multi-Mod)
1700+@2350 2.10V
H20 cooling - home made
mile, welcome to Xtreme! :toast:Quote:
1700+@2350 2.10V
Sorry about your mishap, but at least it sounds like you got a very nice replacement! I'd be happy with it. It's at least as good as my 2100+
I got my friend to go to the computer fair in Nottingham, to look for these chips. He got lucky and picked up 2. Both are good for 2ghz @ default voltage
:p
This is on an ok in my opinion air cooling system, cant wait to get one of these on my slk-800 + delta 80mm 5800rpm 80 cfm fan.
:D
U dudes with water cooling and prometias must be having a great time with these chips.
I will post my findings when my friend posts me the chip, i should have it here on tuesday to go inside my new 8rda+ and Corsair PC3200 LL modules, hopefully i wont have the issues alot of peeps have been having with these modules.
Just a few details of the chips I know of they are both 0302 chips I wonder what the next batch of these are gonna clock like??
:eek:
L8rs
Yeah, I'm wondering what the 0303s will be like. Right now, there really isn't much difference at all between these and the 2100+s. My 2100+ (AIUHB 0301) will do 2.3 ghz @ 1.925 prime and 3dmark stable (air-cooled) , but that's about what these puppies are doing.Quote:
:eek:
L8rs
Got my JIUHB running at 2333 right now. 2400 will crash out of prime after about 20 minutes, so hopefully when my pelt gets here I can turn that around.
Had to run 2.1v to get it that high, though. Stubborn bloody CPU.
Update I managed to get into windows @ 2440 and run a Sandra benchmark. This is on an SLK-800 with a delta 80mm 5800-6100rpm 80CFM.
Voltages where 2.05. My temps where looking good at the time 36 degrees celcius on 8rda+ which i prob about 46-48 on the core.
Im presently typing this on my housemates PC because whilst I was trying to attain a higher overclock without increasing the voltages; after changing in my bios cpu interface from aggressive to optimal my bios got scrambled.
I am now awaiting a new bios so I may continue my overclock on this biatch. Anyone think it wise to push more then 2.05v with the cooling I have.......
:eek:
Im off to bed let us know dudes.
2385@2.025. 5-days old, I'm going to go gentle on it from here on out...
AXDA1700DUT3C
JIUHB 0302WPOW
9366237271546
Doing 2700+ (2167MHz) speeds at 1.975 vcore. Prime 95/3d mark 2001 stable. Best $100 bucks (CDN) I've spent in awhile :D
I'm also very surprised at how cool these chips run compared to their palomino brothers. At 2700+ speed, full load watercooled = 38-39 deg C.
I had a 3 1700 0302 JIUHB to test, best I could get was 2250 stable at over 2.1 volts. Today at work I picked up a 0302 AIUHB 2100 and am now running at 2320 prime stable at 1.825 volts, much much better chip. This chip will post and load windows at 2250 at default voltage and is prime stable at 2100mhz at default voltage (1.58 - 1.62 fluctuation). I think I will keep this cpu even though it'll cost an extra 60 bucks (canadian).
Oh yeah, just using a Volcano 7+ with the cpu fan running at 5000 rpm and a the side panel open (using come cheap case just for testing), have a small house fan blowing in the case, to make up for no case fans.
I think this cpu will hit 2500 in air, but the air will be too loud for my tastes, perhaps I will try watercooling soon.
Nice result on the 2100+. Just make sure you avoid the 0301. Mine will only do 2209 at 1.81v. Takes 1.925 to get to 2300.Quote:
I'm getting a JIUHB 0302 1700+ today to replace my AIUHB 0250 2100+ which is the worst 2100+ overclocker I've seen.
1.6v, max stable is 1850MHz.
1.7v, max stable is 2000MHz.
1.8v, max stable is 2083MHz.
1.9v, max stable is 2155MHz.
2v, max stable is 2.2GHz.
Is that not just the worst AIUHB 2100+? My JIUGB 0251 1700+ does better!
Anyway, fingers crossed my JIUHB 0302 1700+ is better, better than my JIUGB 0251 1700+ also
I wish I had better cooling... :(
Interesting thing is that all the 'bad' 1700+ Bs seem to have almost the same letters after the stepping: JIUHB 0302 WP*W.
I've seen three of 'em (including mine). None of them can do 2,2 GHz at 2,0V.
Mine is a WPBW, freeloader (the Canadian guy) has a WPOW, and JCViggen had a WPCW. All of these were 'bad'.
My new 1700+ JIUHB 0302 WP*W is here.
And is perfectly stable at 2173MHz with just 1.9v, time to push it more.
Edit: Now perfectly Prime 95 stable at 2.2GHz(11x200) at 1.9v. Maybe time to go higher again :)
This is my 0302 JIUHB with plain 20C H20 and 2,2V on 8RDA with no mod and no fan on NB :banana:
http://digilander.libero.it/DiabloII...5.68%20Mhz.JPG
Brainstore "Nice result on the 2100+. Just make sure you avoid the 0301. Mine will only do 2209 at 1.81v. Takes 1.925 to get to 2300."
Actually funny thing was, I was off on the week number, of that good xp2100 I was testing, it is a 0301 tbred b lol.
I'm finding that even with identical markings / batches these cpu's are hitting much different max speeds at default voltage.
I traded my 2100 xp 0301 for a 0302 and it hits a little higher mhz at default voltage, almost 2200mhz so i'm keeping this new one instead.
