I was thinking that too with my first run on my Opty 154, and wouldn't you know it, lol? :rolleyes: :Quote:
Originally Posted by Dani
http://www.cryo-laboratory.com/uploa.../14x26432m.jpg
Was that a good 32M run or bad run:p:
Ok, that's great info from where I gonna start (CPU GHz)
I'm not quite sure, but I thought it would be at least under 20min since I've completed 32m with my FX57 @ 14x262 in 20:04 :confused:Quote:
Nice work Dani :toast:
Nice clocks and SPI time. :toast:
Good work Dani =)
Ilkkahy's brazed container:
3570MHz IDLE
3570MHz LOAD
..did'nt remember to take photos of ~3.8GHz IDLE vs. LOAD temps:slap:
..and here is some 1M running @ low CPU speed
I have apparently tested multi 14, did'nt remember that:confused: :p:
http://koti.mbnet.fi/dani69/DFI%20nF...1M_22.891s.gif
HOW ? :slobber:
We have FX-57 @ 3.92 and it manages SuperPi1M only in 23s !!! :(
Yes, I checked your SP1M time @3.91GHz, there is something upside down :wth:
SP1M @ 3.91GHz with 2*512mb @ 280FSB tight should give nice time around 20s. (if it is a error less run;) )
Yup, you guys are WAAAY off...something's wrong big time:Quote:
Originally Posted by TaPaKaH
http://www.cryo-laboratory.com/uploa...4/14x2721m.jpg
Isn't that stuff TCCD or something? No way it could run 280 2-2-2...Quote:
2x512MB OCZ EL PC4800DC Platinum @ 3.4V
And if that's a typo, 3.4v sounds very very low for BH5 at 280MHz...
2T, or otherwise very relaxed timings maybe?
Good job clocking that FX, Dani :up: Do you have any good 32M for me, please? :D
Also, why do you guys keep using "your" version of SPi? What's up with that? Can't you bench what now most of SPi benchers use?
Wow...good call there Gautam...didn't even notice that....Quote:
Originally Posted by Gautam
The actual DDR voltage was 3.5V.
About the chips: don`t know about `em myself (didn`t look unter the heatspreader...yet (don`t want to lose warranty because i`ve broken two kits of this mem already)).
Timings: 2-2-2-5 2T no performance modes whatsoever. It isn`t stable at these timings. (can hold no more than a couple of minutes then system freezes).
Looks like you have some derivative of BH5 in that case...and 2T and default timings would be the reason your pi score is so much higher than expected. Running pi at a very unstable speed never helps times either.
Thanks guys !
Now i know why my SuperPi is so slow.
I would never thought that it is the DDR.
Going to order some more DDR... tomorrow.
But don`t know which manufacturer. I thought that OCZ PC4800 is the best.
Was wrong. Very wrong. Is GeIL ONE BH any good in OCing ? If it`s not, what is?
Thanks BA!Quote:
Originally Posted by bachus_anonym
"Our" version of SPi is the version we in Finland challenge in SPi, but should not be a problem to me to run SPimod 1.4:toast:
Will do that next time, 32M too:fact:
..but it will take a while, because I gonna test DI next time with solid container
http://koti.mbnet.fi/dani69/Kuparikipot/Kuparitanko.JPG
http://koti.mbnet.fi/dani69/Kupariki...paritanko1.JPG
Here is one of my container's, I noted it has 2.38" high solid bottom and 3" outer diagonal.
3mm thick wall and base thickness is around 10mm
Should it work "well" or better than brazed container:confused: :slobber:
http://koti.mbnet.fi/dani69/Kupariki...hja_sis%e4.JPG
http://koti.mbnet.fi/dani69/Kuparikipot/61mm_solid.JPG
It's TCCD, and no wonder he's already killed 2 kits already :DQuote:
