I have increase the voltage/stability:
http://img105.imageshack.us/img105/8259/pi8m9hy.jpg
New Spi Personal Record Memory Timings @ 2.5-3-2-8
http://img105.imageshack.us/img105/9...3185mhz1tt.jpg
Try playing with the LDT and Chipset Volts it will help you get more out of your chip. I can hit 3060 on air after playing with those volts.
I'm going to have to get my LS out pretty soon b/c last time I used it I got it 3300 dual prime stable, but after playing with those volts on air I think I could go higher on phase.
I will have my water setup here by the end of the week. What does your WC loop consist of?
Edit: What stepping?
Kinda a sub topic in this thread.
I'm really considering getting the FX-60. Yeah the FX-62 is gonna come out in June (or whenever) for AM2, but the only difference wil be 200 mhz, and DDR 2, so the FX-60 should remain pretty valid for a while.
I'm really liking the FX-60. I was going to get another FX-57 to replace my retail one, but the FX-60 is looking very nice. :) They are overclocking it seems on average about as well as the FX-57 on water/air. Some even better, no?
Should I pull the trigger on one? These forums have me eating ramen for dinner.
*Edit: FX-60 on the way. :)
You say to i increase the LDT/Chipset Voltage?Quote:
Originally Posted by Coroner Kyle
The esteping is in the 2 Post of this Thread.
My WC:
Radiator: Black Ice Xtreme 3 Whith 3 SilenX Pro
Block: Nexxxus XP Silver
MB Block: Mips
GPU Block: AC Aquagratix
Pump: Lading Pro
Low Flow System, Plug & Cool.:D
Very good FX...
Mine CAB2E0536 need more volts for 3.2GHz run...
http://img128.imageshack.us/img128/7...88gt8my.th.jpg
Just for reference what kind of temps are you guys getting on water with the FX-60. Seems so far like the FX-60s have had the IHS put on properly, and don't load to high.
Indyxc
Nice clocks, but crazy temps, you guys running WC in like 8c ambients?
Cpu temperatures are not real, Dfi Xpert Bug, ambient temperature arround 18ºC.:toast:
Nice clocks can you do some 3dM runs?? Whats you;'re best prime stable speed?
way
Definitly would like to see some runs..
Yeah; it would be great... ;)
Very nice cpu, wish I had the money to buy one :)
Sweet chip! I agree, chill that hydrogen dioxide:p: ;)
What a nice fx... nice also your Natchy.. where did u buy it? :D
Wow, very amazing :eek:Quote:
Originally Posted by rcl
Here an "low cost" Opteron 170 0550VPMW @ 3150 MHz
watercooled with an aquarium-chiller, watertemps +15C.
http://img48.imageshack.us/img48/718...10032zq.th.jpg
joe_cool :toast:
Very nice cpu. I hope mine does nearly as well, I have the same stepping:
ADAFX60DAA6CD
CCB2E 0536RPMW
1334991L50030
New results, 1st Dual PI 32M run
http://tudovende.com.sapo.pt/dual%20...%203150mhz.JPG
That's nice... :)
I got the exact same stepping. Woot! :banana:
I won't jinx it, but I'll test it tonight, and see how she does with water.
The goal is at least 3000 mhz dual prime stable for 4 hours.
RCL- whats the highest you got yours dual prime stable?
Yes... Can you give us the Prime numbers please?
yeap correct........there's a massive thread over at DFI street...........you need to report your problem too :toast:Quote:
RCL- What is the max speed your FX60 is dual prime stable at?
I have the same stepping.
Mine passes dual 32m SuperPI, at 3000 at 1.5v, over and over again, but it won't dual prime at 3000 mhz, even with 1.6v at this point? :confused:
