Better get on Fugger;)Quote:
Originally Posted by FUGGER
I feel the need for speed:D
I'll continue benching in a few days, I think if I redo the 7800 mounting I should get some better card clocks, enough to get into the 49k's anyway:D
OPP
OPP
welcome back opp:toast:
It kinda has a cold bug but it's the best chip I have, in fact it's the only CPU I have:DQuote:
Originally Posted by s7e9h3n
I use it in my 24/7 PC, runs fast!!
OPP
Good to see you again Eric. :wave:
You running that under one of Dave's cascades??
Expecting some front page domination again from you. And at almost $900 a pop, I can see why its your only chip atm. Then again, I recall seeing a pic of either you or MrIcee of a closet full of motherboards at one point, so one cpu is a little surprising.
How's the school work treating you?
Yep, still useing my PCIce cascades, got three of them here.Quote:
Originally Posted by Hell-Fire
I do still have a closet full of Motherboards, but yes only one CPU, unless you count a couple of 650 Durons :D
School is slow right now.
OPP
I wanna see you strap one of those durons under your cascade there:DQuote:
Originally Posted by OPPAINTER
Nice :toast: I assume that's on water? When you say "Kinda" what does that mean specifically? So far this 154 I got today is quite a beast. I've taken it as high as 3920 (14x280) @ 1.66Vcore at only -43C in windows. It's capable of much, much more but I've got a bad mount and my bh5's didn't want to go much higher @ 3.65V :p: Sorry for the OT....Quote:
Give him a break Fugger!! :stick: Your gonna run him off again.:DQuote:
:eek:Quote:
Looking forward to my first unit from him. Curious, since those were some of his earlier units, what gases and compressor hp are you running? Hope this isnt a one time hitter from you...you plan on sticking around for abit this time. ;)
holy crap! what is it benchable at?Quote:
welcome back opp!
Haven't completed many spi runs because of the bad mount, but it's at least 1m good at 3710 (14x265) @ 1.60Vcore. I tried it @ 1.57Vcore but it errored @ the 17th iteration. If I had good contact, I'm sure it would have been able to finish......Quote:
Originally Posted by vapb400
When I say cold bug I mean I have to run a Ricky Tweak in windows to heat it up or else it will freeze when cascade is colder then -80C. It works perfectly fine up to -80C though, no tweak needed. My cascade does over -90C though so it becomes a problem.Quote:
OPP
Nah, he needs a push.
:rocker: and he will be on it for the next few days. Good chance of some serious 2K5 and 2K6 damage.
Forgot to mention, with the server things out of the way I will update my 3D scores with cascade. Current stuff up is vapo/air
Thnx for the info :toast: . Luckily my evap temps don't usually drop below -75C while in windows so I may be just inside cold-bug territory with my autocascade.Quote:
Good to see Opp and FUGGER pushing out the results again. I'd like to see Eric with an XT1900 and I'd like to see Charles' Intel under cascade, in 3dmark06 as well.
Regards
Andy
Im at work, 5:07 AM bolting up the cascade. Plan A is to DICE the GPU.
Just wait till i get my phase change unit and i'll try to give all your folks a run for your money - a few cpus to test on phase :DQuote:
Originally Posted by eva2000
Will that be the SS or Cascade variety, and would you like some fries with that? Practicing for my job at McDonalds after I graduate with my engineering degrees. :hehe:
Picked up 1K over Opp on the first run, closing in on 50K
http://service.futuremark.com/compare?2k1=8892852
nice job guys, id help but 01 likes to crash with crossfire :F
Nice run Fugger!! :toast:
Is that 2 cards or one? Do those ATI cards have any cold bug issues?
OPP
I've not heard of any coldbugs yet in the ATI cards. I'd like to see you play around with them in crossfire.
I wish I had a couple:DQuote:
Originally Posted by HousERaT
OPP
oh stop with that...... I'm sure someone might "lend" you a few just so you can bring some nice publicity back to ATI. :DQuote:
Two cards in crossfire on air.
Ill be working on scores for a few more hours.
