Here is the mounting hardware and evap. The idea behind these parts was to be simple to assemble and to use minimal tools and time to build.
http://img315.imageshack.us/img315/717/fourmount8fi.jpg
The mounting hardware is made to sandwich around the socket to keep condensation from creeping on the board and gives a sturdy base to attach the evap. Right now its setup for a 478 never got around to drilling holes for the LGA on the lower section.
http://img437.imageshack.us/img437/199/evap3vi.jpg
(Image was loading horribly slow resized and uploaded)
And the evap probably not the most efficient but it seems to work. The capillary tube is brazed in the center hole and a thick copper disks brazed to each end. One disc has a hole which a fitting for the cap tube to exit and the flex line to attach the other becomes the base. This was not my original design I ran into a problem while making the block and didn't feel like cutting another.
Nice, i liked very much your case.
omg 0.0 that thing is sweeeeeet.
I couldnt stand not having my stuff in a case though, but that thing is still kick A IMHO.
if thats really your first one, your a natural :)
NIce Rig.. I lke hte "MESH" Look ;)
Super Job!!:cool:
How did you do the lettering on the case??
? with a paintbrush and white color ? :)
Its great getting all this positive feedback it will probably push me to make another.
Anyway the lettering is done by masking the top then found a font I liked printed it out taped it down and cut it out with a razor, peel away and paint. Its awful doing this on perforated metal because every time you hit a hole it goes chunk.
I see in one of your initial pics you have a transformer which I assume is being used to power the fans (stepping down from 120v to 12v? but I don't see a rectifier bridge, or something for filtering (which doesn't matter THAT much for fans, but a capacitor would do) I'm not really great with electronics, but that didn't look right? (maybe they're AC fans?)
The rectifier is tucked under the compressor probably can't see it from the picture. I wish I knew enough about electronics to build a simple controller but this is about as complicated as I get, maybe some day I’ll take some classes.
oh, ok. you might want to put at least a passive heatsink on the diode bridge, I know when I built an unregulated linear power supply for my GPU peltier setup it got hot as heck, although your fans aren't drawing as much current, might want to leave it out in the open for some fresh air.
Damn! That looks really good, nice work. The mesh looks exceptionally hot ;;D
Where did you get the compressor? Do you have a link?
The compressor is from ebay but that was back when I was still trying to figure out how this stuff went together. I remember it being something stupid like 20$ with shipping I should have bought everything they had, long gone now. :slap:
Thank you for the sketches that on ace of the eva: D is very good work, besides some good results with this eva.
I believe that in a future it plows an eva for the GPU of the graph: I find D very good results.
Greetings
