TY, :)
Regards
Quent.
TY, :)
Regards
Quent.
@KoNiaK and quent,
Can you guys see how high are those Optys benchable? Are those 1M-benchable @ 3.6Ghz or higher? Any other benches, please? :)
hi, i have to fix the single phase before testing.Quote:
Originally Posted by bachus_anonym
Not benchable @ 3.6ghz 4 the moment :(
great dude !! :toast:
27th WR for OCM :D
WOW someone finally took my WR down.. Good job! Any benches?
Comin' soon :)
i was wondering how many volts did u throw at the sucka....
the one i tested gave 3511 SS with 1,82vcore.....
maybe next time i will increase it a bit:D
edit....btw....great score
Congrats on your first WR...very nice OC!:toast:
I'm gonna broke 3800mhz soon, puting the single phase outdoor with -10°, I hope -30°C CPU :)
3757 = -15°C CPU.
Very nice clock! I can't break 3.4 on my 148 even at 1.8V :D
:eek: :eek: :eek: :eek: :eek:Quote:
Originally Posted by quent
:woot: :woot:
IMPRESSIVE
very very nice clocks, lets see some 3.8
I'll breake 3.8g whitout any problem with the single phase fixed.
-10°C <=> +70Mhz
I broke 3753Mhz with proc @ -15C, with -25 or -30 ( ambiant temp at -/+ -10°C ) i could hope 3850Mhz :rolleyes:
Let's see Quent :D Awesome chip indeed!
Sorry for this off-topic question, but what piece of software is that you are using to monitor temps/voltages?Quote:
Originally Posted by s7e9h3n
That's MBM (Motherboard Monitor) ;)
pretty sure that MBM.
Oh right, thanks guys. I've used MBM before but never remembered it looking like that.
That's the "dashboard" of MBM5 ;)Quote:
Originally Posted by Brett
Cooling: PromieQuote:
Originally Posted by moddolicous
Stepping: 46 0540 CABYE FPBW
Chip: around -10C
Sweet point: Around 1.6v
I had to raise voltage that high to reach -10c; sweet point is around 1.6v can't remember what voltage I set in bios. Does it have any impotance?
This chip is amasingly hot, won't even pass OCCT @2100MHz 1.36v IHS is real bad on this stepping.
I couldn't answer because I was in the process moving accross the Athlantic for a while. I let my phase change in europe, so I won't improve it any soon. I had to do this real quick, that is why I didn't bench at all. Didn't try any other bios or tweaks to go higher. I Got this chip from someone I know in a small german store. Just before l had to leave :rolleyes:
Amasing your venice accept -48C mine won't show any improvment under -20/-25CQuote:
IHS on or off?
Thanks. What's worth a thread isn't easy to define.Quote:
Originally Posted by SoF
If I post in one of those big thread I won't be able to folow it and answer questions. So I prefer to create a new thread, sorry every body!
But I always answer sooner or later, which isn't the case of every body. I think it to be really important to help each other improving our scores.
:woot: I knew it gad to be broke soon :DQuote:
Glad to see it coming from overclockins-masters; keep the good overclocking guys :toast: I was a member once but can't remember you :confused:
Unfortunatly I won't be able to compete due to the reasons I explained before.
How can you be so sure that your opty can accept lower temperatures?
I banned you ( for 2 days.. :D ) because of a thread "o/c my penis" :rolleyes: , you may come back mister ! ;)Quote:
Originally Posted by KoNiaK
This stepping don't coldbug harsh, and he loves cold. I'm sure he'll accept -25 without any problem.
edit : u made a mistake : New WR by quent: "3"753MHz :D
What!!! I never created such tread! You must be wrong; you weren't on the forum when I was :rolleyes:
Well my won't progress below -10 will see if I got the bad appple :/
Gona correct this sorrry
Oh, sorry i probably made a mistake. :D
