I just got 2 of 0536UPMW from Mwave.....They have 3 more left today, which is part of 5 pack with the same stepping.
Show us the spi run and maybe we can help ;)Quote:
Originally Posted by Dumo
Check herethis one's not too bad ;)Quote:
Originally Posted by guess2098
Something I find a little perculiar, AMD had retail FX-60 CPU's ready in week 36 of 2005. I think it is safe to assume tht if they wanted to they could have released the FX60 back then? Yes, im aware they have a road map, but would this be the reason they didnt release it? The silicon was ready for retail as there seems to be quite a few 0536's knocking around.
Then we see a 10 week gap (going by the results of this thread) before the next silicon is produced, anyone care to stipulate why? Has anyone spotted, FX-60 stepping on a X2/Opteron duallie CPU?
guess2098,
think its far to say tht with the lower voltage, AMD are producing better silicon :), hopefully this will be seen in better IMC and less cold bug issues (discussion on this would be too off-topic). As eva2000 mentioned, FX-60 CPU's produced in 2006 will be a very interesting item for us to see.
11/14 bios.....Evap. temp.@-33C is the sweet spot..
http://img29.imageshack.us/img29/978...shot1469se.jpg
http://img29.imageshack.us/img29/982...shot1499gb.jpg
Comparo with the other 2.6Gig proc....
http://img11.imageshack.us/img11/83/...t0157ak5qe.jpg
What are you using for cooling LS ?? :)Quote:
Yep, LS.Quote:
Originally Posted by Dynasty
Dynasty, where you got the 0548?
Guess 0536SPMW and my 0536UPMW......see the difference?Quote:
Originally Posted by mongoled
http://img293.imageshack.us/img293/7...shot1506br.jpg
in canada local supplier :)Quote:
Your revision is JH where Denny's is DH.
No kidding!Quote:
Originally Posted by eva2000
Dumo any 3D 05 or 06 tests yet ? :)
no idea just speculation and hope on my part that 06xx are better hehQuote:
Originally Posted by Cpt Twitchy
That one result isn't much to speak for but with all of s7e9h3n and OPB's ;) referring to 06 chips give hope hehe.Quote:
This is terrible. My Vapo LS is salivating and my bank account has got the sudden feeling it's going to be reduced by about 850 pounds sterling.... :rolleyes:
:D thats funny. These chips are really looking to be beasts.Quote:
Originally Posted by stone_cold_Jimi
Dumo, I forgot to say what an awesome chip you have there and I'm sure #2 will do the same for you:toast:
Tim
lol..why 3? and do you have to set affinity for each? btw, i sent u a pmQuote:
No affinity, 4 and 5....vapo temp scaled higher really quick to -25 evap.
Past 3.5 Ghz on a dual core, good work Dumo.
Thanks Absolute.....gotta keep this cpu busy above -36C evap. temp @>230htt.
@Dumo: What's the max voltage you've run through your 60 and do you run 1.68 regularly or just for benching? What are your idle and load temps like with that much voltage?
@stephen: What are you cooking up?
Kyle, I set 1.525X113% (just for benching) in bios and Vapo evap. with fluke dt shows -28C load....idle reached -36 and it froze..
What kind of volts are you running for 24/7 on your vapo? I should have a UEI DT200 hopefully tomorrow or the next day and then we can accurately compare temps b/c my smartguardian is showing positive temps under load. Is your vapo modded?
Its stock vapo. When you ran long benches the SG probly hit 255 and went to + temp.Quote:
Originally Posted by Coroner Kyle
I always ran stock when not benching.
So far I've only benched and I guess I will probably just go stock for gaming, etc. What's your opinion on this?
I'm going to try to run these volts when I get my vapo back up and running to see what they will give. I hope it's a fuse (I've only had it for a week).
