Opteron 170 0546XPMW
DFI NF4 Ultra-D (earlier rev.)
Watercooling
2.75ghz@1.47V
http://img209.imageshack.us/img209/9...2v12hrs4sl.jpg
Watercooling
2.75ghz@1.47V
Ok heres mine:
Opteron 170 CCBWE 0546 XPMW
AB0 ultra-d SLI modded
512*2 redline UTTs
boxed cooler with COLD air
2.85ghz 1.62v
http://afireinside.evilspork.net/AFI...h/285032M2.JPG
Opteron 165 CCBWE 0534 SPMW
AD0 ultra-d SLI modded
gskill 2gbzx (redlines at the time)
big typhoon + 129CFM reverse delta, IHS removed
1.65v 2.8ghz 24/7 dual load stable
http://img.photobucket.com/albums/v4...GN/2800DPS.jpg
keep 'em coming folks :)
Oteron 165 CCBWE 0547TPMW
DFI NF4 SLI-D
Generic Samsung PC2700 DDR (TCB3) 512MB x 2
Thermaltake Big Typhoon
2700MHz@1.36V
2799MHz@1.42V
http://img69.imageshack.us/img69/7066/16527990cp.th.jpg
Update:
Oteron 170 CCBWE 0530 TPMW ; Batch #022 ; IHS on
DFI Expert; Thermaltake Big Typhoon
2x 512mb Redline xp4000
2850Mhz @ 1.39V (air temp = 21C)
http://i1.tinypic.com/mhpwg1.jpg
More voltage does no good :rolleyes:
Opteron 165 - CCBWE 0546 MPMW - Air cooled
DFI NF4 Ultra-D
2x512 OCZ VX
2.700GHz @ 1.36v (don't have a pic of that though)
2.786GHz @ 1.48v (v. high temps)
http://www.tkd-uk.co.uk/Upload/Pic/SP32M-2786MHz.jpg
bump
What where your "dressed" results? ;)Quote:
Originally Posted by Pete@X
This might add something to this thread I guess...
CPU : Opteron 170 (stepping CCB1E 0550VPMW, batch 334)
Cooling : DangerDen TDX water block
Mobo : DFI nf4-D mod SLI and SATA2 (bios 11/14)
Ram : 2*256MB Gskill TCCD 431
Overclock : 3G@300*10, vcore 1,5V (1,52V in bios)
http://i9.photobucket.com/albums/a10...%20170/300.jpg
Opteron 165 CCBWE 0546MPMW
2700MHz @ 1.45V on air
VERY nice iMAX :clap: :toast:
Hopefully when I get a little more time I hope to get my 170 to your levels :)
Opty 170 0550UPMW.
2800mhz stable at 1.472v.
My first post on XS :D
Opteron 170 CCBWE 0541 on Asus A8N32-Sli Dx.
10 x 250 @ 1.45v (I believe it's stable at 1.40 as well) on stock cooling.
Opteron 170
CCBWE 0546
Asus A8N32-SLI
Danger Den TDX
10x270@1.55v, 48C
2.8GHz 1.49V with Big Typhoon
CCBWE 0530TPMW
I rarely save "stable run for a long time" screenshots. I'll do dual 32M right now if I find spi (never run it).
http://img84.imageshack.us/img84/351...spi32ms1kq.gif
Too bad it doesn't scale with higher volts :fact:
Hiya ...Quote:
Originally Posted by ChkDsk
well ... "dressed" was also possible to prime @10x300@1,584. It was stable - but temps were a bit high ... so naked i can run 3GHz@1,55V 24/7 with "easy" temps ;)
Opteron 165
CCBWE
Msi neo2
Prommy
http://overvoltage.pt/forum/imagens_...5_superpi2.JPG
CCBWE 0551VPMW
289x9 = 2600mhz at 1.47vcore. I can't even get to 2650 with 1.6volts .
I'll attach screenies sometime later.
Opteron 180
CCBWE 0543UPMW - Naked
DFI SLI-DR
2900Mhz @ 1.68vcore
10+ hour Prime stable
Water - Swiftech MCW6002-64 CPU Block
http://www.fragtek.com/pix/opty_10hrprimestable.jpg
http://www.xtremesystems.org/forums/...6&d=1135308833
Max windows stable suicide OC = 3100Mhz @ 1.68vcore
http://www.xtremesystems.org/forums/...1&d=1135439254
Opteron 165 0550 UPMW
2500 MHz XP-90 air, 1.30 V BIOS, 1.26 V measured (-0.05 V from default)
2670 MHz XP-90 air, 1.325 V BIOS, 1.28 V measured (-0.025 V from default)
http://kometv.no-ip.com/images/Opteron165_278.PNG
I will update this post as I continue to find stable clocks, I'm not done yet.
Opteron 170 CCBWE 0550 UPMW (408)
3.2Ghz @1.53v 24/7
PCIce Single Stage phase change
DFI Ultra-D AD0 Bios 704-2BTA
2GB Mushkin Redline
Big Typhoon
DFI NF4 Ultra-D AD0
Crucial Ballistix PC4000
Max clocks on stock volts- 2547MHz
http://img81.imageshack.us/img81/875/25471359rf.th.jpg
I run 2700@1.475 24/7 but I have no screenie, I will update this post after running prime overnight.
EDIT: Here's my new max clocks.. 302.7x9 set in clockgen haha. 303x9 fails strangely enough after 3 hours. Voltage is 1.350x110=1.485
http://img437.imageshack.us/img437/7...14566ss.th.jpg
Don't mind the time displayed in prime95, it does that whenever I use clockgen. Actual time is a little over 23 hours.
I think this thread, along with the single-core Opteron database thread, should be sticked to so people can get the information they want. Nowadays there are a few retailers that disclose the stepping information.
Oteron 170 CCB1E 0550VPMW
DFI NF4 SLI-D
Thermaltake Big Typhoon (Open-air testbed, Ambient temp 15C/60F)
2900MHz@1.52V
<a href="http://imageshack.us"><img src="http://img504.imageshack.us/img504/2923/2900stable15ij.jpg" border="0" width="1600" alt="Image Hosted by ImageShack.us" /></a>
<a href="http://imageshack.us"><img src="http://img72.imageshack.us/img72/1906/2900stable25vg.jpg" border="0" width="1600" alt="Image Hosted by ImageShack.us" /></a>
Opteron 165 CCBWE 0551VPMW :D
Zalman CNPS9500
DFI nF4 SLI-D (704 -2)
I'm running my opty165 24/7 at 2.75Ghz can get it up to 2.8Ghz but it needs 1.6v to do it.
http://img526.imageshack.us/img526/8...m52s0ui.th.png
Opteron 165| CCBWE 0551VPMW |2745Mhz | 9 x 305.1Mhz | 1.53v | 2x1GB OCZ Performance dual channel PC3500@PC4200 | 274Mhz 3-4-4-8 | 2.64v | DFI nF4 SLI-D (704-2) | Zalman CNPS9500
