Thanks a lot guys! It took me 5 days total to finish all that :lol: I don't have much free time lately as I used to have :( So, I did a bit at a time...
I think it is... Coop had his 148 up to 3564Mhz on DI (and Weee @ 3554Mhz on Jin's phase) but I'm sure he could squeze a bit more. I can *almost* finish 32M @ 3600Mhz (it goes thru 16 passes and then craps out :() so maybe there some more steam left in there :) Ah, 3530Mhz fir 3DMark2001 seems to be max. I can actually run it pass 6 first tests @ 3560MHz but It hard-locks right after Nature fades in... It might need some tweaking but I'm sending this card out today or tommorow so I will not find out...Quote:
Originally Posted by loc.o
Thanks a lot my friend :toast:Quote:
Originally Posted by yotomeczek
I have two OS installs on my HDD. One is Server (benching with "multi-tweak") and other is regular WinXP. In WinXP @ 3500Mhz @ 1.65v MBM shows -27C IDLE. BIOS temp at same settings is -23C.Quote:
Originally Posted by T_M
Well, actually that's the 3rd (or 4th) 7800GTX 512MB I had sent to me for vmodding in the past 2 months. This one is the last for now as I really don't have enough time and energy and to do it :pQuote:
Originally Posted by s7e9h3n
Thanks for the offer, man!... I'm gonna try it on my own first as I have a feeling this chip won't go very far under ~40C BIOS temp (maybe another 100MHz, If lucky) :shrug: I don't want to waste other people's time in case I'm right ;)
Thanks AFI! I was watching you and few others that were first running those Optys here and decided to jump the wagon as well :) Njkid32 had few of them and decided to get rid of one. Awesome guy and a timming for me :)Quote:
Originally Posted by afireinside
I have to use it or otherwise I can't boot to Windows at above 350HTT and low temps. I have actually run 16M on this chip up to 386x9 so far. I bootet to Windows at that 386x9... And like Yotomeczek said, it's more of the CPU thing than mobo. My SD 3700+ have not seen that type of HTT in its whole air/phase/DI life!Quote:
Originally Posted by dinos22
System is not under load per se (CPU usage is 0%) but temps are shooting up like it was. It's even a bit hotter on IDLE that LOAD. I see about 1C drop from IDLE to LOAD :D Neat, eh?
Thanks Vince :toast: Maybe I won't hit 4GHz in 1M like you did (big congrats :up:) but it's still a nice one. Very impressive piece of silicon, considering it's only $200 piece of hardware...Quote:
Originally Posted by k|ngp|n
