Started dirty, turning sexy...
Keep it up :D
Keep it up :D
Looking good there
Is the rad mounted on the outside of the case?
Ontop the case actualy. It will cool water and act as an exaust for air, while not optimal it will do just fine.Quote:
Originally Posted by v0dka
Im going to take that as a compliment,Quote:
Originally Posted by Shinuza
And thanks guys for the encuragement.
yeah i cant wait to see what you do with it next
talk about 56K warning!!!!!!!
Originally Posted by best [486]
Sorry about that.
Well a little update.
The 80mm to 120mm funel I painted.
http://home.earthlink.net/~brukla/im...6/DSC01467.JPG
The rear end I moded and painted.
http://home.earthlink.net/~brukla/im...6/DSC01469.JPG
Not all parts a completly polished yet.
A small update.
I mocked up the lower loop.
I aded a valve for easy drainage.
http://home.earthlink.net/~brukla/im...6/DSC01473.JPG
http://home.earthlink.net/~brukla/im...6/DSC01474.JPG
Here is the rear mocked up.
http://home.earthlink.net/~brukla/im...6/DSC01476.JPG
http://home.earthlink.net/~brukla/im...6/DSC01477.JPG
And the drainage tube.
http://home.earthlink.net/~brukla/im...6/DSC01479.JPG
wow this just keeps getting better.
this thread is definately something awesome
Great work so far, definitely has the potential to be a top class piece once it's finished. Hope to see more piccies soon:p:
Thanks guys. I will work on the case a bit lader on this week.
I hope it tourns out aswell as I picture it in my mind.
Wow this is turning out really kewl, I love the look of polished metal:)
Thanks.Quote:
Originally Posted by Dj SpecialSauce
Very nice work, cant wait to see it finished. This is quite an intricate project.
Well I am update time.
These parts are the plastic pices under the front of the case. At first I wanted to paint them black and gloss em up. Then I decided to add a bit of shine with some aluminum tape.
This is how the bottom part looks like.
http://home.earthlink.net/~brukla/im...6/DSC01503.JPG
This is the top.
http://home.earthlink.net/~brukla/im...6/DSC01504.JPG
I also painted and glossed my psu bracked.
http://home.earthlink.net/~brukla/im...6/DSC01505.JPG
The digitoc moded and painted black and clear coated. I havent installed the circuitry yet on it though.
http://home.earthlink.net/~brukla/im...6/DSC01506.JPG
Another shot.
http://home.earthlink.net/~brukla/im...6/DSC01507.JPG
This is my aoc fan I was using in my old setup. The fan aged and started making more noise. So I guted it and put in a TT silent fan in its place. The old blades in chrome didnt do it for me so I used the TT fan blades and since they were orange I painted the blades black and put a gloss coat ontop.
This is a pic of the rear of the fan with a plexiglass ring covering the housing that was painted black and clear coated.
http://home.earthlink.net/~brukla/im...6/DSC01508.JPG
and the front of it.
http://home.earthlink.net/~brukla/im...6/DSC01509.JPG
Thats about it for now.
Im working on the front bezel now.
Well I painted the side panels but only polished the rear panel.
I also mounted the rear 120mm fan and mounted a grill filter in the rear.
Here are the pics.
mmmmmmmmmmmmmmm......shiny.
http://home.earthlink.net/~brukla/im...6/DSC01518.JPG
More bling.
http://home.earthlink.net/~brukla/im...6/DSC01519.JPG
Closeup.
http://home.earthlink.net/~brukla/im...6/DSC01522.JPG
The rear fanfilter.
http://home.earthlink.net/~brukla/im...6/DSC01525.JPG
And the rear fan. I know the case has some dust in it and will be cleaned before final assembly.
http://home.earthlink.net/~brukla/im...6/DSC01527.JPG
Thats all. For now im fine tunning the front panel and sanding and preapring the other sidepanel. I also mounted some rubber feet on the case to increase the heaight of the case and for noise dampening.
:slobber: Nice work.. Complete Custom! :clap:
You should run a TEC with that setup.. :banana:
I can't wait to see the final product.. paint and turtle wax looks nice :toast:
i love seeing your posts, keep it up!!
jaguar, you do good work.. cant wait to see the finished product
thanks guys. Means allot coming from xtreme guys.
As for running a tech. I dont want to run one for the time being. I have a chiller in the works for this summer as a project. It wont be main rig cooler however. Just a benching device to see what certain components can do. Im expecting liquid in the -20 to -30c range with the chiller.
wow this is a fine job, can't wait to see how it will look @ the end
Very nice, keep up the excellent work :)
Been following your project, excellent work. :clap:
