what bios are you using with your DFI LANPARTY ZIZI?
I need to find one w/ vdimm 4v.
I just got mine and still testing. near 2.9 w/ 1.7v
Hello JAWS
The bios i am currently using, and that was used for the benching is jess1313's BIOS. It supports 4.0v vDIMM in the bios though you will have to do a vdimm mod or adjust the pots on your 3.3v line in order to get any voltage above ~3.2...but then again you knew that already(just a precaution...lets just say i got "threatening" PM's on another forum from a disgruntled teen, telling me that i directed him a rotten BIOS....:slap: )
Well anyways here is a link to the BIOS, i am using the A15.
http://webpages.charter.net/jess1313...20Beta%20Bios/
I have had good experience with it but as always your luck will vary.
Good luck with the OC :toast: !!
[ZIZI]
Originally Posted by [ZIZI]
thanks for the link!!!! will try later. :)
no problem man.
be sure to post your results and stepping :toast:
[ZIZI]
ADA3000AIX4BX
CBBWE0544BAJ
X008867K50111
seems to top out around 2800-2850 with air. I tried A15, but with no luck so I'm stuck with 623 bios. man I wish I had more than 3.1v. :(
