Cant wait to see what you can 32M at.Quote:
i did this screenshot a while back, when i had venice core...and ocz platinum rev2, 2x512mb ofcourse...:cool:Quote:
328htt@2.5-4-3-7@2.8V vdimm
<a href="http://imageshack.us"><img src="http://img505.imageshack.us/img505/610/328sp1mb283758nb.jpg" border="0" width="1024" alt="Image Hosted by ImageShack.us" /></a>
now i moved to san diego core, but i didn't play much with my ram...maybe i can go over 330htt...;)
masni, your SP1 time seems a bit slow. With 2.95ghz (295x10) with 2.5-3-3-5 TCCD I get 27.7 seconds in 1M.
Odd thing though, is that all my ram (TCCD and UTT) hates tight TRC.. TRC hs to be at 12 or above. Usually 14.. But everyone else I see runs it at 7-9..
about my sp1m time, trcd 3 is a important factor, 2.5-3-3-x is much faster than 2.5-4-3-x...or maybe you have opteron or san diego with 1mb cache - this is also a important factor...generaly, cpu with 1mb cache calculates SP faster than cpu with 512kb cache...(venice vs. san diego)...Quote:
Originally Posted by MaxxxRacer
i didn't notice this about TRC, i always use 7, only when i push my memory over 310htt, then i put 12, 14 or higher...your case is a bit odd...:confused: :D
I,m pretty sure we can reach DRR700 1M ;)
for the people who are interested, here are the timings.
CPC=1
Tcl=2.5
Trcd=4
Tras=7
Trp=4
Trc=7
TrFc=14
Trrd=2
Twr=2
TwTr=2
TrWt=2
Tref=3072
Twcl=1
Dram Drive strength=7
Dram Data Drive strength=2
Max Async Latency=9
Read Preamble Time=5
IdleCycle Limit=16
R/w Queue Bypass=16
Bypass Max=7
i will be very impressed if you can do that, as i played with my geil one (0519) the other night, and at similar timings i was reaching similar speeds, 330-335 1M stable.Quote:
Originally Posted by Hugo van Dijk
i need to use T2 to get to 350, but if you can do that @ T1 then :toast: :woot:
targ
1T depents on the mobo and the cpu, not the memory:)Quote:
Originally Posted by targ
and hugo i still didn't recieved a pm from Jan
Damn i wish i can mod the Mach1 to mach2GT asap to cool that cpu a bit,
cold memcontroller is also good for the memory:D
