LOL in 05 on last one I see 3-4 fps all day, I know this is all cpu driven but still, I bet this is gonna be what 06 is like for me...
most 3dmarks are horrible when they come out, but they get better. They show Nvidia and ATI what they have to do to get higher scores.. Just another generation. a Generation to were you'll have flies flying around, and all around BETTER graphics.
~Mike
so i should be able to get 30FPS... :p:
You can only hope at this point :banana:Quote:
Originally Posted by freecableguy
We still can't be sure thou... :DQuote:
Originally Posted by Tim
Last time I checked, [the most recent versions of] 3DMark was a benchmark designed to beat the most powerful systems to a pulp.
Looks like it works to me.
LOL dont get in a hissy, thankfully 3dmark does not correlate to todays games. Well 3dmark 2001 does correlate the most but at this point 2001 probably corelates more to superPI LOL! 11fps with two 7800gtx sli? thankfully todays games run great on a $50 video card!
Good thing 3dmark isnt a game ;)
maybe on your 7" LCD, with your world record 9700pro run on a Pentium 1 200mhz:DQuote:
Originally Posted by Geforce4ti4200
you are so obessed with 3dmar 2001, get over it, it correlates more to my bell end, than it does to modern games.
hmmm, i remember when i first broke 10k in 3dmark2000:) i had a little party im sure
i dont know why but i get this strange addiction to these damn benchmarks!
Have you guys been wishing for this ??? lol It seems we'll be seeing it quite soon. Courtesy of HKEPC.
http://www.hkepc.com/bbs/attachments...n20UmqToIL.jpg
http://www.hkepc.com/bbs/attachments...jvaoZmRhcc.jpg
- More then 350 Million TransistorsQuote:
ATi 將 會 於 2006 January 24th formal 發 佈 All the new higher order 繪 圖 cores R580, 而 且 亦 designation because of proper form Radeon X1900 series, 雖 way 傳 hearing 已 Hisashi 但 one direct not yet you see, the true body, 但 the HKEPC compilation 輯 section and the 怎 會 叫 pursuit new east west 讀 person disappointment 呢 The 獨 house 找 來 ATi R580 true body 曝 light, yes from here watching arriving at R580 Die Size and the Shin one 步 變 Large Ryo, the 如 fruit from here about 90 奈 American systems the 來 說 如 此 Above enormous Die Size phase trust 將 會 compiling excess 3.5 hundred million electric crystal 體. Furthermore at the time of reality ATi not yet direction factory trade stopping intersection R580 core formal standard, merely road 將 會 amount because of knowledge, 3 edition books and floor because of the highest Radeon X1900XTX and the taking generation 舊 possession from here PE designate method, at the time core because of pulse, at the time of 650MHz and the memory 體 because of pulse rule 1550MHz. At the time in Radeon X1900XT core because of pulse at the time of 625MHz and memory 體 because of pulse rule 1450MHz. 而 CrossFire edition book 亦 會 resident in same day 發 佈 At the time core because of pulse memory 體 because of 625MHz 1450MHz. 另 Outside, ATi direction factory trade being transparent dew Radeon X1900XTX required minimum 450W power source offering/accompanying 應 vessel, 30A 12V export and 如 fruit right rack 更 like 1900 CrossFire rule required use 550W power source offering/accompanying 應 vessels 12V main point offer 38A export Hasama ヘ.
- Formal Launch in January
- Low clocks in the beginning, not final product - 650/1550 ?? :confused:
- The X1900XTX will require a Minimum 450W PSU
- Crossfire for these will require a 550W PSU as minimum
- Or A PSU with minimum 38A 12v Rail
Rest of it I can't decipher.
Perkam
Cant they just put the last sentance, dont care about PSU W, how much they drain from rails, thats more like it :D
I just hope they get away from CF / SLI soon - 2 freakin' expensive :P
Hicks, Im not tryin' to defend Ti4200, but, 01SE is still the most fun IMO, reason?? - The score depends on tweaks / HW skills, not just equitment.. :)
yep. just too expensive for normal people...Quote:
Originally Posted by M.Beier
@ Thread;
damn 11 fps with these cards .. i wont believe it :stick:
Here are the changes added to the x1800xt pcb:
Circled in blue are the elements added in the x1900 "hkepc edition" pcb
http://img371.imageshack.us/img371/4120/gpun16638qh.jpg
http://www.vr-zone.com/?i=3073
Our friends over at HKEPC has got hold of a X1900XTX card already and the R580 die size is noticeably larger than the R520. If the process technology remains at 90nm for the R580, the estimated number of transistors stand at 350M or more compared to 321M for the R520. Radeon X1900 XTX will be clocked at 695MHz core and 1550MHz memory while the Radeon X1900 XT will be clocked at 625MHz core and 1450MHz memory. ATi has revealed that Radeon X1900 XTX will require at least 450W PSU with 30A in 12V rail. If in Crossfire setup, the system will require at least 550W PSU and the 12V rail will need to provide 38A.
Those power requirements are insane, damn.
well i do know that my OCZ 600w couldnt keep my pair of 512's running in SLI even with no overclock or vmods
had to use a separate PSU for the GFXs only to be able to 3D bench hehehe :slapass:
I think it's a good thing, what good would it be to bring out a 3dmark that runs well? Noone would be compelled to buy new hardware, that is probably the major purpose of 3dmark, to get people buying newer stuff, it works and it looks like it will work again...
this will run fine one next gen cards in sli cf and that is what they and the vid card manufacts want...01 is by far the best tweaking windows and so on u can see what u change and how it effects it...03 is only starting to necome fun...
DRAGON
can you say 140W of heat? yay!
and i think 2k6 will not be a benchmark only, there will be a game based on that engine i think :D
wich will be really nice!!! :D
is it me or did they use low mega pixel cam to disguise the writingvs on the ram....
my guess---> 0.8ns
:D
did you check out the last line in the link.
That is not 3D Mark '06. It's a joke. And the next version should be '07 if you follow the number sequencing.
:clap:
PCmark 2002Quote:
Originally Posted by lio256
PCmark 2004
PCmark 2005
3Dmark 2000
3Dmark 2001SE
3Dmark 2003
3Dmark 2005
Now why shouldnt there be a 3Dmark2006? - that thing with ATI cat 5.13 is a bit :banana::banana::banana::banana:ed though :S (13th month on a year, huh)
is it still the same case for X1800/X1900, that separate PSUs for nvidia cards are okay but separate PSUs for ATI cards can potentially kill ATI cards due to the electronic/power circuitary on ATI?Quote:
Originally Posted by Blaster
Why would they use 0.8ns ram and clock it THAT low?Quote:
Originally Posted by Willis
It's the same ram on that's on the X1800XT, 1.2 - 1.26ns...
0.8 isn't even in production phase, much less mass production, so there's no way we're going to see a X1800xt with anything remotely close to that.
1.1 is entirely owned by NVidia, as reported by the Inquirer.
It's definitely 1.2 or 1.26ns... A pity really, this thing is going to cry for more bandwidth!
