Yes and no. The 2400+ I have is only good to around 2250Mhz with my AX-7 in a closed case. That's as high as I got with my KR7A-R too, 2250Mhz (180x12.5). Now after this mod I have the voltage to match that CPU speed 2258Mhz (214x10.5). I can run almost Prime stable at 2300Mhz (219x10.5) with the system cover off and 2v Vcore. The best I could do stable before the mod was 2200Mhz (220x10), I needed 1.9v to hold that speed. SO after the mod I got my 50Mhz back. Wow, what a bunch of crap for 50Mhz. :DQuote:
Originally posted by TechTones
The highest I can take this chip is like 2200. Did cutting that trace allow you to OC the CPU higher?
Water cooling would change everything of course. With WC you have the ability to run high power levels to the CPU. This mod won't improve on the power limitations of the board though, that remains the same. The mod only lets you run at the absolute maximum CPU power the board can deliver without shutting down due to tripping the overcurrent protection. Unfortunately, the maximum power may not be a stable power. If you really plan on pushing this board that hard, I'd definately add some heatsinks to the MOSFETs and the IRU3055.
If I was a betting man, I wouldn't bet on being able to match that 2500Mhz clock you had on the other board. I don't have a real warm fuzzy feeling about the quality of the power section on the 8RDA+. It's really a shame because this board is so close to being able to dominate anything around.
Let's hope the rumors of a suped up version of the 8RDA+ being in the works is true. I'd buy it.
