15,000watts :woot:
15,000watts :woot:
FCG, what is your opinion on Zippy power supplies for dual opteron servers?
They have a model with 45 amps on a single 12v rail at 700watts.
I'm not sure what makes you think my calculations are linear...Quote:
Originally Posted by onewingedangel
As originally posted:
110*(3600/2800)^2*(1.65/1.4)= 214W
Obviously NOT linear. I'm willing to concede that this was a simple oversight but if not, I advise not using words you don't understand the meaning of...
Can't go wrong with Zippy although I don't have as much experience with that brand as say, s7e9h3n...you should PM him for more information on the best model for a dual Opty system. As you know (or should), I am building a very high-performance dual DC Opteron system right now and I selected the PCP&C 1kW for that system also. Better to have TOO much power and a lower total system capacity consumption than too much... ;)Quote:
Originally Posted by z-design
-FCG
my system in my sig pulls about 2.3-2.9Amps under load. lcd included.
i have a kill a watt unit also. after booting the system it jumped 2.3-2.9amps. It Actually peaks 3amps+ on boot, then in windows it drops under 2.5amps.
Its very interesting tho.
i have kill-a-watt connected to:
27" Sony FD tube TV
600w stereo system
direct tv tuner
1500va UPS
17" LCD
my Computer in sig
Dsl modem
Dsl Wireless router
and all of that above at load doesnt peak over 6.5amps.
U = 115V ?Quote:
Originally Posted by Dissolved
FCG is rigth!
My OCZ Powerstream 600 cant handle my SLI rig, proved it just some minutes ago. Everytime i started 3d benching, computer would just shut off.
The rig includes: Prommy, Opt148@ 3200Mhz, DFI SLi-dr, 2 hitachi hdd, audigy ZS, 1 DVD-RW, 2 GTXs 512Mbs and 4 case fans
I had to use another PSU to power the GFXs and from then it works perfectly
Uh oh do I need a 800 W PSU now? 2x7800GT in SLI with some (overclocking using nv silencers probably), X2 3800+ probably or Opteron, 2x512 OCZ 3700 EB memory at 2,9 V, Vapochill XE and 2 Raptors, 1 7200 and a 120 mm fan?
Even a seasonic S12 600W should be able to handle that one I hope and a 510 ASL for sure? (same as 510 SLI)
Originally Posted by biohead
yes.
you could run your system on one of those but not sure for how long. Honestly I would be looking at a 1k or something of the like.Quote:
Originally Posted by oqvist
I have:
raptor
120gb ide drive
3 delta fans
2 CCFLs
2gb ram
dfi nf4
165 @ 2.8
x-fi
7800GT SLI 500/1180 vmodded
DVD burner
My OCZ 520 smelt like BBQ 24/7 running rosetta and caused some instability once 3d came into play. I put the cards on an OCZ 420 and I'm ok now.
