Originally Posted by Fred_Pohl
I fail to understand how anyone can be disappointed with Yonah's performance in this very early review. IMO Yonah did very well considering that it was crippled by a low FSB (533 or 667) that can barely feed one core, let alone two cores. The low FSB and subsequent lack of sufficient memory bandwidth is what kills Yonah's performance. Especially in the encoding tests. Also, the increased L2 latency, while hurting performance a little, should permit much higher clock speeds than Dothan can run with it's lower latency L2.
As for Yonah consuming more power than Dothan, should this surprise anyone? Did anyone expect two cores with double the cache of Dothan not to use more power? Instead of comparing a bandwidth-starved dual-core Yonah with a single-core Dothan, we should compare it to the X2 and note that even crippled as it is, it performs just as well clock for clock and consumes far less power. Keep in mind that Yonah is a mobile CPU that matches the best desktop CPU available, clock for clock. Just imagine how Yonah would perform if it wasn't bandwidth starved.
