Very nice man...I am getting some help on using OverClocker.
I am not sure what volts to use and what not though.
i'm still at stock volts myself but used ATI Tool to bump GPU volt from 1.275v to 1.3v for last run heh
I am as well because I have been using ATI OverDrive to overclock...and I am at the max it will allow me to set.
Thought I would add this...
690/800
http://i5.photobucket.com/albums/y19...ark05-9895.jpg
Same here UGP, i doubt we will be able to up the volts, these cards run pretty hot.
I just tried the oc utility, at 695/810 05 was fine, almost 9800, then tried 702/820, and i froze in the middle off 05, and gave me a serious errror warning, and said to restart the machine? is that the core or the memory?
I am not sure..I believe that is the core when it just hard freezes...my 6800s did that...It needs more voltage I assume...
My x1800XT doesn't run all that hot...6800s ran hotter than this does.
EDIT:
:mad: The battle of CPU Stability continues...
Really dam.
This is reaching 80odd C load, it's about 56C idle, not messing with fan speed.
Yeah probly the core, ill leave it, and try and up the memory i suppose. Is the memory the same as usual, if it's to high you just get artifacts?
You will get artifacts then...
my 6800s ran about 84C full load.
Where do I find service manage in windows?
Start > Settings > Control Panel > Adminstrative Tools > Services
or start > run > services.msc ;)Quote:
Originally Posted by IvanAndreevich
Or right click My Computer and choose Manage :)
Found an interesting quote regarding ATI Smart.
"The ATI Smart service is a bit more vague, as it is not needed for the ATI SmartGart settings to work. It continually detects system conditions at boot time and adjusts SmartGart settings if needed to maintain stability, but in effect it's just a useless resource hog."
Taken from Tweakguides.
I apologise for bumping this thread :(
Where can I get a working ATI OverClocker tool?
I've tried it and mine says "No Valid Devices Found! Requires an ATI Radeon RX5XX Based Adapter!" :(
Any1 know where to measure the volts manually from this card?
Originally Posted by Sume4
here you go:)
Thanks m8 :)Quote:
Originally Posted by SIOUX
nice scores guys those x1800xt are monsters
