Originally Posted by Unoid
your advantage over a conventional waterblock is that by using heatpipes you can locate the water to metal junction in a spacier area. Therefor you need to take advantage here and make the contact with the copper fins that will be comming off the heatpipes with the wate r to be huge. Think of those giant heatsinks with tons fo fins and heatipes. You need to basicly make a complete box around those fins and have water flow over all those fins or something close to that. A higher water volume will make for better cooling.
also rmeember that you'l want the inlet being on the lowest part of the box, and the outlet at the highest (hot water rises to teh top, plus it will get rid of air bubbles that float to the top) thats based o nyour current picture.
you could have both inlet and outlet on the top as well.
