It might be good to ask cpuz why it's reading 194 etc. I don't think it's bs since the venice that was unlocked also had the missing x-64 instruction just like yours. I think you should download version 1.31 though. http://www.cpuid.com/download/cpu-z-131.zip
Also you might want to try cbbid and everest and see if it adds any info about the x64 instructions. The other guy rma'd his over the x64 although I would probably consider a decent trade even if they don't still work. The only way to really know would be to install a 64bit os which I don't think he did. I have a feeling the id bit is probably screwed and not the instructions themselves.
So congratulations I wish mine would unlock! How did you discover that it was unlocked? Did something happen or did it come that way?
