Very nice clocks ! :D
The only limiting factor of my Suttle SN45G was the Bios ;) Max FSB was 250MHz, but the heatpipe cooling was very good with a push/pull setup. Load temp never went past 48°C @ 1.75V
And it sounds even better if you consider, that everything has the size of a shoe box :D
That heatercore is double the size of that Shuttle!! :D
No fans on the heatercore?
two fans (80mm and 92mm)@5volts
@Lagaffe
could you exactly tell me how you did this ??
i have big problems overclocking my opteron144 on my sn25p.
everytime i set my speeds,ht etc. and boot my system only winxp shows me my
overclocked speed.
cpu-z and other progs show me the original opteron144 speed (1800).
i also get this message while booting new settings:
"CPU is now running in safe mode; Please re-setting the CPU frequency in BIOS setup"
shuttle told me that iam using incompatible hardware (cpu/ram)
what a joke...
my ram runs very well and i think its not the problem.
OCZ DIMM 2 GB DDR-400 Kit (OCZ4002048ELDCPC, Platinum EL)2-3-2-5.
BIOS is the latest (Y)
plz enlight me :stick:
Multi 9
FSB 250
HT 4 = 1000
RAM DDR333-166MHZ = 204MHZ
=CPU speed 2250 MHZ
http://www.forum-barebonecenter.de/a...achmentid=5850
you must valid 2x the bios setting (seting valid reboot setting valid et reboot and its good normaly)
by me for exemple
10 x 300 vcore 1.55
coef htt : 3
ram desynchro 166 1T
voltage chipset defaut
@ Lagaffe
could you plz explain in more details ??
i dont get it !! :confused:
go into bios-set numbers-save and exit-reboot-go into bios-set numbers-save and exit...no luck....
still no answer/help :confused:
