http://www.xtremesystems.org/forums/...ad.php?t=49848
Something like Chilly1
Nice block, now get it frosty :D
G
The base might be a bit too thick, but you'll find out soon enough...
Nontheless, nice design :)
hey dude, looks nice your evap. today i have draw the same evap by my self.
i try to make lot of evaps, same as yours i one ime to make cnc.
i work in a cnc factory
ICE COOL
I'd suggest replacing the safety clip with an inox one
This way you' ll avoid rusting from moisture
I've been using this way for mounting my evaps to the enclosures for over a year and i had this rusting problem when i used the same clip you are using
Jack and Eleven u got a point. :(
one more pic
Looking good :toast:
What material is that holddown plate made of?
And something that might be a good idea for next time,
the white piece of pipe along the evap could be made higher
so that is sticks out on top.
Then you can stick the armaflex in there and tape it up
for a airtight seal.
I hope i made sense :D
I made a drawing, because even I didn't understand what I was trying to say ;)
http://home.student.utwente.nl/r.makkink/mounting.PNG
Looks great!
One thing, the evap is in direct contact with the holddown, do you not think condensation will form there?
depends on what material the holddown is made off I think
Jan is using a similar design and isn't experiencing any problems :)
Jack I was thinking of making an new one just like what u show.
Holddown is plexi glass. :(
Since the plexi isn't touching the evap directly, i might work just fine...
Depends a little on how good the white pipe insulates. Test it :)
If you look at jan's design, the evap does not make contact with the white pipe at the top, there is a gap, the only contact is on the bottom where the plastic ring press down on the evap ring.
Bets way is too test it :)
@ Jack
The teflonpipe on the photo above is like my first rev.
Here is the rev.1
http://www.forumdeluxx.de/gallery/da...89IMG_0573.jpg
http://www.forumdeluxx.de/gallery/da...89IMG_0575.jpg
http://www.forumdeluxx.de/gallery/da...89IMG_0576.jpg
http://www.forumdeluxx.de/gallery/da...89IMG_0577.jpg
joe_cool ;)
:eek: thats nice :woot:
Originally Posted by Haar
Thanks !! :D
If you´re interested on a complete kit, pm me.
joe_cool :cool:
Looking good :)
Kayl, now thats worth a sig-quota :)Quote:
Originally Posted by kayl
modded my evap house.. :cool:
thanks joe_cool, but the ID is 1mm too big for my evap.Quote:
Originally Posted by joe_cool
right on :toast: very nice! should work good nowQuote:
And done.... I hope. ;)
i love it, a really sweet block there haar
