If I haven't had such a great mounting job done to my cooler I would have torn it apart and do some air OCs :lol: But I can assure you that it will definetely go higher since I can fairly easy Prime LargeFFT @ 310Mhz for more than hour today. I can run only 1M @ 315Mhz 7-3-4-2.5-1T 2.75v but that's about all for now. I'm not gonna switch to 2T as results are just embarassing :DQuote:
Originally Posted by eva2000
I hate DOS memtest from all my heart and I just wanted to double-check today why :) So, I can do #5 and #8 for about 60 minutes at 300Mhz 7-3-3-2.5-1T 2.75v but in Windows this is so unstable like there's no tommorow :lol: But I'm on a mission now to get "TRCD=3 clocks" up a bit ;)
EDIT: I just re-read your question. Oops :D Actually, I would not be so sure about that, you know George. I don't personally believe in that. especially, since AMD's 90nm, when the colder you go, the worse sometimes it can be. I experienced that with a Winchester and I'm somewhat seeing that now, with San Diego 3700+. E.g, once I see -22C in BIOS, chances are (and it happens) that I cannot even boot to Windows @ 310+HTT. On air, 330HTT is never a problem. So, it's the other way around.
