wow, lots of locals (to me) here that I didn't know about. At least I am not the only one missing out then. If I find cards anywhere ill let you know. Please do the same.
He's already have 7800GTX :)Quote:
Originally Posted by metro.cl
*raises hand* :PQuote:
we got guys pulling 7k w/ a venice and modded GTO2's...
The 7x scores are coming from an FX53 running stock with crappy 2yr old RAM inside a shuttle. Not too bad.
I've tried ATiTool, Rivatuner with no luck. Neither can find the card. I guess it is time to order the Storm watercooling kit with the new Swiftech GPU block to see what I can get done.
Funny thing is it never moves off 63c with my lowflow block that has four other blocks in the loop. Water temp didnt' go up 2c either.
http://home.socal.rr.com/rickcain/images/CCC.JPG
Why dont you try ATI Tool or Powerstrip ? You can set the max possible clock with those so you're not limited.
Perkam
You sure the ole "shim too high" issue isnt biting you?
63C seems nutz for water, even lowflow. Both my X850's had to have the shim's removed, they were not making solid contact with thier heatsinks.
Both of the programs have not been updated and will not see a X1XXX type cards and will not alow any overclocking options.Quote:
Originally Posted by perkam
I say give ita another week for the update to come in.
It "should" fit actually, they both use identical hole layouts...Quote:
Originally Posted by SnipingWaste
erm.. what are YOU talking about lol
:banana3:Quote:
Originally Posted by einCe
EDIT: See below.Quote:
Perkam
Powerstrip will overclock your video card but it has to be running to keep the overclock so it isn't as good as for 3dmark but i'm sure the extra overclock will help out.
Have you tryed Ati Tray Tools ? May be that one has some support ?
And withe the temp. I had the same with my X700. Would not go below 52c. Strange ting. I think a buggy sensor. Of the heat is not transfered well trough the chip.
isn't powerstrip suppost to be driver independant ?Quote:
If thats so i need support for the card. And because almost nobody has one. U cant make the program work with it. If u don't use the drive u must find a other way arround and that takes time.Quote:
Originally Posted by Gnome
Any more updates? Someone suggested scouring the registry to try to tweak CCC to allow higher clocks.
N00b question.... X1800 any better then 7800 GTX?
Answer for ya master... Depends on the application. In some yes, in some no, like how it always is between ATi and NVidia products.
ATI X1xxxhas more image quality options (especially angle-independent AA), but 7800GT/X is available now. ATI X1xxx series will have a greater lead in the future, with games with long shader scripts.
Eh shadow, that's a "possibility", it cannot currently be proven.
Also, future games will use radiosity, and therefore ATi will be at a disadvantage.
lol deleted per request
Is there no ATI winclk for the X1800 series available yet :confused:
This isnt a radiosity thread. Its RickCain's X800XL Results thread. Pls continue that conversation here: http://www.xtremesystems.org/forums/....php?p=1081907 .
Perkam
Rick you need to email W1zzard directly. I think he is working on a beta version of atitools that allows for overclocking the x1800xl.
I posted a few months ago in General Hardware forums on buying 2 7800GTX's now ATI has released this and dont know what one to get :slobber: I can't get 2 though because I dont have a crossfire motherboard.
