your welcome
your welcome
so it will be the FX 61 before they come out with the M2? I see no new core being worth buying before the M2 currently
S939 will never become 65 nm, just like S462 never used 90 nm. I think 65 nm M2 will show up 12 months from now, when nobody want's a 939 except for budget systems.
I wonder what will happen with HTT and RAM speeds. They will use 667 MHz DDR2, does it mean that the CPU will run at (333 x multiplier)? If so, then I guess there will be a long wait for both mature CPU's and mobos that can handle at least 500 MHz bus speeds for some decent overclocking. I don't know if you need new chipsets for the new socket. If not, then mobo manufacturers will probably try to sell mobos with old chipsets in the beginning. A 400 MHz capable chipset is the best for today, but will only give you a 20 % overclock with M2... :stick:
HT will stay the same, but the memory divider will change.Quote:
Originally Posted by Mats
How do you know that? Won't they run at 3x333 instead of 5x200 (HTT)?Quote:
Originally Posted by saratoga
Because that would be both expensive and pointless.Quote:
Speculations...Quote:
However, I hope you're right, otherwise we'll get lower max multipliers and a demand for faster chipsets like I said. I hope we'll find out long before they show up.
may I suggest an X2?Quote:
Originally Posted by eliminate
I think that should be highier up on your list than the M2
The FX59 WILL be a .09 3.0Ghz San Diego core cpu. This most likely will be the last single core processor introduced by AMD. After it's release (which by the way should be expected in the next 2-3 months) AMD will shift it's focus to dual core cpu's. IIRC, ddr2 cpu's will be released sometime during Q2 2006, starting with the Opterons.......
Hehe...hopefully the 1200+ pin DDR2 Opties will do the same :p:Quote:
Originally Posted by Troman
EDIT: THen again, that'll be impossible running reg ecc ddr2 on server boards......
are they definately going to be ECC only like the 940's?
Yeah the Opterons made for multiple CPU implementations will remain with ECC only from what I understand. It just makes so much sense in a server workstation environment... more so than overclockability (I never overclock a serious work computer myself)
Yup, right on point there. The main reason why the s940 single Opteron cpu was moved to s939 wasn't because AMD wanted to create a workstation solution which utilized non-Ecc DDR. Rather it had much to do with the cost of manufacturing for s940 motherboards in general. All current s940 motherboards are manufactured with a 6-layer pcb. This results in a much higher cost for the end-user and therefore very little demand for a single cpu s940 workstation solution. By shifting the socket to 939, the single cpu Opteron workstation becomes a much more feasible solution for those who are on a budget ;)Quote:
Originally Posted by Ugly n Grey
my thought is if you want more than 1 Cpu on a mobo you can afford a $200+ mobo
I think there's at least 6 months until the next FX chip so that puts us right where M2 should be announced. I'll be really surprised if there is a S939 FX-59.
Originally Posted by nn_step
100% of the cost isn't materials though is it? Factor in the cost of building the fab, additional work, testing and packaging costs. You aren't exactly at 50% cost anymore. In fact for AMD, you're probably losing money for the first couple years anyway.
Well I guess your gonna end up really surprised. All the roadmaps I've seen put the FX-59 as a 3.0ghz san diego core on socket 939.Quote:
Originally Posted by IvanAndreevich
I based my estimate on pure manufacturing costs aloneQuote:
Originally Posted by Lithan
Is it the Socket F/1207 that will have integrated PCIE controller? Better 3D performance, worse/no overclocking because of ECC RAM, DUH!!! :stick:
I want both!! Will AMD really stop themself from making THE gaming machine by not using the integrated PCIE controller in A64? :confused:
You guys forgot about R&D cost, each fab lab can cost up to several billion dollars.
But do you really want to lock your self into exactly one type of Graphics card connection?Quote:
besides the latencies for graphics aren't that bad...
What's wrong with PCIE? Unless you have X850 AGP lying around which I don't.Quote:
Well, I was just speculating, or dreaming.. we don't even know what that PCIE controller can do in reality. As usual, wait and see... :slap:
Lets see, Oh I know the fact that is going to be replaced within the next 18 months :slap: PCI-E2Quote:
Well, good for you then. :toast:Quote:
you don't plan on jumping on the bandwagon too?
