have you tried switching the LDT/BUS Transfer width to ↓8↑8 like the japs?
waiting for pics ;)
No... Should try that but ice is almost done :( trying to get off one last 3d01 run but ram wont cooperate...
37.6k 3d01!!! Switching to my daily rig to upload pics!
well, it's friday night, and i can only hope you don't have to work tomorrow, nor any other necessary engagements that require you to delay further experimentation
I'm 15, no work for me :D Getting dry ice first thing tomorrow.
http://valid.x86-secret.com/show_oc?id=40974
3250mhz CPU valid
uploading pics then 3dmarks
so wait, w/ lesser clock, you got a higher 3dmark01 score??? was this done w/ same vid card used for scores in your sig?
It was used with my modded x800pro @ 618/605 and CPU at 318*10 /12 ram divider for 265mhz 2-2-2-5-8 2*256 BH5
rig:
http://img.photobucket.com/albums/v4...GN/optyrig.jpg
(insulation just for show :p: )
http://img.photobucket.com/albums/v4...IGN/32501m.jpg
http://img.photobucket.com/albums/v4...IGN/32508m.jpg
suicide shot at 3250, very nice, what is max stable?
VERY nice AFI!
Good to see that the added voltage did help, too.
I'm popping her cherry in the coming minutes....these temps are outta control, even on water (48C @ 3090MHz, 1.5V). I honestly think a Big Typhoon could out perform my water though :stick:
that's 8m 3250 stable
3250 is max stable... I don't SS and never will. Hell 3300mhz won't even BOOT. Maybe if my ice hadn't melted.Quote:
http://service.futuremark.com/compare?2k1=8736982
37619 3d01
3250 is max stable? Well to qualify for the stable let's see some Sp2004 :)
http://service.futuremark.com/compare?2k3=4293430
3d03 14457
It's my bench setup, I'm not wasting time running Sp2004 on it. If it runs pi/3d it's stable.
i'd be happy with a 3.000 24hr prime stable on a big typhoon, that's my goal
damn all of you guys with your shiny new Opterons. You're making me want one now. ;)
I don't want to sound nit picky but if 3160 is your max 3d stable then 3250 cannot be considered your max stable. That said i'm very impressed with it and it must surely be primestable at 3100 Mhz or so, which is excellent.
What are the idle/ load temps?
Look in the pics for idle... Load at 35C or so? I don't really pay attention, I was getting slaughtered with AIM messages on my laptop.
I ran 3d01 at 3180 cuz it maxed my ram. I'm sure higher was stable. I'd say 3250mhz 8m a max stable clock...
theres is absolutely NO POINT in running SP2004 or prime...its his bench rig...hes gonna bench...what dont you understand
well i'd like to know where it's max stable is and i dont consider 8M stable, obviously i'm not alone here. at any rate if he has no interest in finding max stable that is fine, i'm content to see the high clocks, they're very impressive.
Ok max BENCH stable how's that? This is purely OCing for benching. If you want to see max stable OC then I'll show you my clawhammer at 2.8 24/7 when I get a new watercooling setup for it.
the irony kills me :DQuote:
Originally Posted by Vandi423
looking good AFI, got anything to say about the memory controller yet?
YES! Yes indeed I do. Forgot to post it in all the excitement. I had to run 8ns async 7ns preamble to get over 3050mhz and I changed from 2-2-2-5-7-13 to 2-2-2-5-8-15 to get 265mhz 3d stable again. I also changed some other timings from 2 to 3. Not sure if it was needed or not.
very good...........your PI time is slower than Japs....i know they ran Win2003 server which would help a bit
