This is S939, right? I guess CPUZ is confused about S940
Did you really have to answer this question ;)Quote:
Originally Posted by IvanAndreevich
Sure is a 939!!!! We wouldnt be kicking up such a fuss abt a 940 pin CPU would we? Unless we had a time machine and gone back in time, LOL
heheehee
lol socket 940 is pretty shot
Wow, sounds tempting considering its price
Originally Posted by afireinside
Take a look here
:toast:
heh.. it has it's purposes. 8-way dual core system is one of those purposes. no matter how high i overclock this wimpy 144, it could never ever ever touch that kind of power :toast:Quote:
Max screen is nothing ... what about stable or bench like SPI 32M ?
Or SPI 1M, it's always nice to know :)
i'll get that info in a bit after i get this terrible stock cooler off and a TDX on :toast:Quote:
Originally Posted by computersmsa
availability yet in US??
C
it's scarce, but there are a few places with it. if you really need one, give vandi a shout out :DQuote:
Originally Posted by charlie
ozzi, how goes the water cooling setup? what's your setup consist of?
DD TDXQuote:
Originally Posted by VulgarHandle
DD maze4 (not in use due to pci video card)
mag3 pump
'77 bonneville HC with 1x120mm delta
got it in right now, 30c idle 35c load at stock voltage and mhz. the as5 needs to break in a bit, and i'm not used to having a heatspreader :p:
lol, oooh, strip that opty of it's confinement
i want to, but i won't, because of how poorly the tubing in my loop is set up, and i don't feel like stripping it down and setting up again to make it all better. i'd like to not have a repeat of what happened to my newark :p:
he should hook all of us up lol. may have to shoot him a pm because of this :woot:Quote:
Originally Posted by ozzimark
he doesn't reply to them :(Quote:
Originally Posted by asianguy80
Good, don't. I want to be the first :DQuote:
so are these opertons the EXACT same as a A64?
i haven't tried yet :p i'm pondering on which chip to get still i'm leaning towards the 146Quote:
Originally Posted by dinos22
There is speculation that opterons have better silicon... also it looks like they have a 1mb cache.
from an AMD PR guy:Quote:
"939-pin Opterons are tested to a higher standard than Athlon 64, and do go through additional testing."
it would be logical to deduce that higher standard = better silicon.
So in theory you are saying that these first batch of opty's will be the best 939 1xx series available.Quote:
Originally Posted by MickeyMouse
sounds like it. i'll respect your opinion on the matter MM, and believe what you say for now. time will be the true test, but i do recall what happend to the first revE's :toast:Quote:
what happened to the first revEs???
All I know is I was one of the first to order from monarch and I got stuck at 2.5 ghz with my venice.....
Yeah, it always seems like the first batches of CPUs OC best. Remember winnies? Everyone was doing 2.7+ at first then they just sucked.
if that is the case haven't the 939 opty's been around since late summer or something liek that? I think I read that somewhere but I forgot where.
