well...i think it depends on which kind of soldering tip u got^^Quote:
Originally Posted by cold_ice
mine if pretty huge...
i also needed only a few minutes for all the mods but it wasnt that easy as i thought before.
Can someone meassure the vcore at the point "the stilt" has marked in his pics!
I have not modded my board atm, but with 1.4V in Bios it's only 1.17V without C1, Speedstep and other crap under dual prime95 !!!
The vdd droops also from 2.3V to 2.1V (other mosfet)...
PSU is a silverstone st60f -> 600 watt!
i can measure it tomorrow when my new bios chip arrives =).
And now?
My board undervolts heavily! mosfet measure with multimeter under load @ 1.45V bios vcore -> 1.18V !
The same thing everest read out: 1.18V!!!
It's under dualprime95 and with c1 and all other things disabled...
PLS measure your vcore at the mosfets...
Try checking Vcore at the points I marked in this post.
At the points that you are measuring on the MOSFET, there will be a high frequency square wave switching between ground and +12v. A DMM will take the average of this voltage and produce a low reading.
Thank you very much!
The mods are great! Big thx to "the Stilt" :D
The mods aren't easy to solder with normal 30 watt equipment..
Hey guys,
I've got an ASUS P5LD2 and the vcore is also not stable under load (usually drops about .08V). I'm running a Pentium D 820 with a Big Typhoon and am currently at 3.85Ghz stable with a Vcore set in the bios as 1.4125. I can't seem to get much higher than that, and its not the temps: full load is about 56C. Higher voltages don't seem to help at all either. I've tried multiple powersupplies (ocz powerstream, modstream, antec trupower) and the vcore still seems to swing the same amount under load with each so i don't think its the psu. So i decided to plot the vcore over time as i ran two instances of stressprime to see exactly what was going on. It seems that the machine will reboot or lock when the vcore has a significant drop (~0.08V). I guess I could keep bumping the voltage up higher like 1.475 or so to get 1.4 under load but that doesn't seem like the right way to do it. Hence why I think this mod might help me hit better speeds, but does anyone know if this mod for the P5WD2 (955 chipset) will work on my P5LD2 (945 chipset)? Thanks guys.
Dan
yes, thats exactly what i mean...Quote:
Originally Posted by Entsafter
hm, gut it doesnt matter at all... board doesnt boot any longer... dunno y.
seems like i have to rma it.
I don't have 30K ohm VR available, but will try with 50K ohm VR.
This is my first Vmod, but at least I have the right tools now for the job. :)
Hey success !
A challenge to solder in such confined tracks on mobo, but hey... no Vdroop now ! 50K ohm VR works OK so far.
Now the mobo when O/C will do as I say....:D
I took a 50k Vr too, works very good :)
Me2!
There are no 30K vr available here in switzerland.
Yes, the CPU is very stable now when moderate O/C... but heat is now a real problem. H2O here we come...Quote:
But not for long with 630, 3 weeks untill 661 ! :toast:
Does anyone know how to control Vdroop on Northbridge ? you have to solder VR somewhere ?
I love the solering The Stilt has done :)
REALLY NICE.
