Man, I have alot of pics from when it was made...
here is another killer one:
http://overclockingpin.com/container%20making.jpg
Thats a pretty one... cnc is awesome for this work
Nice indeed. Now go for 50K, fast :D
nice work k|ngp|n
how long did it take to complete all up?
cheers,
the_chad
wow
thx for the vid
looks awsome, if i can get into a machine shop in the next week or two im going to do a dice tube
Wow awesome CNC vid :)
How long total worth of cutting did it take in the CNC machine?
Like interior exterior and everything?
you need to work that gpu, shamino i much higher you could take him down if you get that kind of clocks.
keep it coming 50k is so close
nice tube kingpin. i love this solid container
It took longer than if it was in a production run because we had to make sure that the tool that was designed to make my base, was doing what we wanted...and it wasn't at first so there was alot of trial and error.Quote:
Originally Posted by justwOo
If I decide to mass produce these, we can spit them out at around 1 piece every two hours or so :) That turning machine is the most amazing thing I swear.
Spent most of the day prepping this p4c800-e I got on ebay for 80.00 bucks :) Full mods for making a dothan scream, mounting, and condensation prepping for something close to -200c takes awhile....that and I am a slacker.
Got to run a few quick benches before the ln2 was all gone, and early on it's looking really good for xtreme ln2 stuff. I manged to get almost -189c loaded temps with about 1.65v on the processor. These are the best temps I have ever gotten on any dothans I've tested under load. The container started hissing loudly as the ln2 boiled off when the temps got below -165c..it was crazy. It must have something to do with the way the base is designed.
Didn't take long to get the chip up close to 3700mhz after seeing what the board could do. What sucks is I couldn't get this mobo to run some of the same ram settings at high fsb as my other good p4p, so I may break it down and hook that other board up for the rest of testing. Dram lat par 11 and 200fsb boot = huge jumps in scores for pi if your board can do it. With both of those settings, I would have had mid 19 sec with this 770 easy. 20.25 sec for 1m was my previous best for 770m but on p4p800.
Also not so sure about this chip, it needs more voltage than my other one did at same clocks, but I did mange to get it 1m stable at nearly 3450mhz with about -120c and 1.6v which is close to 780m performance. 780's like lots of voltage, and so does this one it seems. It should do well at 1.75v+.
Here we go again....
http://pic8.picturetrail.com/VOL256/.../112491262.jpg
http://pic8.picturetrail.com/VOL256/.../112491267.jpg
http://pic8.picturetrail.com/VOL256/.../112491273.jpg
http://pic8.picturetrail.com/VOL256/.../112491258.jpg
This score could be much better with the setings I mentioned above. Something like .6 to .8sec total drop in score.
Very cool lookin forward to other results! Any way to redo the first pic w/o the skull on the bottom? lol :toast:
That is sweet man.
Sweet Trail of Dead poster man. And awesome initial results. That tube sounds kickin.
nice work, awesome tube once again, and i like the skull :D
That hissing sounds wild, must be very quick at transfer. It looks like you have a winner there KP.
PAtent?? O well as I said before get it published and its yours forever patent it and its gone as soon as someone sees it...Quote:
Originally Posted by k|ngp|n
What I mean is this.. When ever youcome up with some design make sure to get the drawings notarized.
send then to youe self and publically display the pics..
THis will show you Own it..
THe other issue about Ln2 containers is what you are doing,, the action performed and how it is done. So Not patentable..
Copywrite the look and feel.... YOu copy a design so someone comes up to you and says did you build /sell/ that to so and so.. then that is enforcable...
Thanx for the valuable info reggie. I have already learned some of this on my own from meeting with others. I'll show the design as soon as I am done testing it's effectiveness. No biggy.
Nice design man it must feel good to know that you probably have the "coolest" thing around. Hopefully you can throw some volts at that CPU and get a nice 4ghz superpi run in.
-1...8...9... Celsius loaded. Absolutely awesome. :worship:
Looks great k|ngp|n, awesome work. :woot:
Doesnt this tube provide you the spot for the arc? i dont see the arc :D
Was wondering the same thing. Nice results Kingpin. When are we gonna see 18's? Also, are u gonna try another run and get 50k?? Cant wait. HURRY UP!Quote:
Originally Posted by Waus-mod
Kingpin are you planning on selling these containers once your happy with the outcome?
Thanx, it's actually a QOTSA poster form when they toured with them, but they're cool too :)
http://pic8.picturetrail.com/VOL256/.../112639790.jpg
Been really busy with other commitments atm, so i get in testing when I can. Did a little bit of pentium M stuff, but I have to work out some p4c/p4p mobo issues first, before I can max either of my chips out. I may runs some single card 3d action on the p4gd1 in the meantime. I want to work the container through a whole range of temps and loads. I manged to get both my 770m and the 780es stable at around 3400mhz with DI temps. These clocks are good for those temps.
770m 206x16 -68c
http://pic8.picturetrail.com/VOL256/.../112643543.jpg
780m 201x17 -77c
http://pic8.picturetrail.com/VOL256/.../112643125.jpg
Much more to come there of course and sorry for the lousy pics.
I did some quick fx57 2d stuff today, and it did great. I matched my best 8m clocks(mhz) to date with DI temps easily. I also got some runs in 1m to pass at 256x15 which I think is around 3838mhz or something. Thats my best 1m mhz too.
http://pic8.picturetrail.com/VOL256/.../112637800.jpg
http://pic8.picturetrail.com/VOL256/.../112637796.jpg
Focus is on the container right now, better multi and ram settings will come later for that stuff. As far as ln2 goes, benching with it has been a dream. My temps barley swing at all under load, even with the fx at 3.8ghz and 1.82v bios.
http://pic8.picturetrail.com/VOL256/.../112637793.jpg
More updates soon, incuding arc stuff :)
Edit out the skull :)
lol
Im gonna go to san fransisco(store) or something and get something trippy like your skull D:
It's cool
