At least a picture of the ZM9500 with the 120mm fan? And results of the TT Big Typhoon with the Delta would be great too.Quote:
Originally Posted by Dani
:toast:
:toast:
how about adding a spacer and reversing the fan on the BT? :D
Yes, it was on my mind, 60mm spacer to 120mm fan is optimal, hmm, should try ;)Quote:
Originally Posted by STEvil
How load/silent that enermax cooler are?
Enermax UC-12FAB / 120mm:Quote:
Originally Posted by Kasparz
- Low. 1500 / rpm n. 67,3 Cfm. 34,0 dB
- Med. 2000 / rpm n. 81,0 Cfm. 38,0 dB
- High 2300 / rpm n. 94,9 Cfm. 43,6 dB
Here is my 24/7 settings with 2x512 Mushkin Redline XP4000, Enermax @ 1090RPM :D
http://www.thermaltake.com/dcfans/Co...2330/a2330.htm
Damn i got excited but its just near same specs as one they inc with BT, we need a 120 or 130mm :D Silent Cat as it was best fan ever for rpm/cfm/db its same rating as these bigger fans at near 54cfm (52.4cfm) i think.
That fan would be hard to seal around a heatink as its round sectioned, or maby not, any ideas if it would gain you anything ?
Sweet review! Looks like I'm getting a Big "T"!
But one question, whats best, Tt Big typhoon+VF700Cu or Tt Big Water SE+GPU waterhead from Tt?
The CNSP-9500 is available at newegg.
http://www.newegg.com/Product/Produc...82E16835118223
this is a test in open air, how about those 2 in the none opened pc case?
tt bt is so bigger that it will effect the whole fan cooled channel or wind direction? anybody have notice this? in a none opened case, the fan cooled channel or wind direction is also important .
Here is a interesting review:
http://www.xbitlabs.com/articles/coo...t-coolers.html
nice work! awesome..
dun kid..u gotta show the pic of modded 2 fan 9500 to us :D
so you sanded down with 800 grit and then use polish?
got a link to the polish stuff?
800/1200/1600/2000 I belive, an then polish, correct me if I am wrong :toast2:
yup. polish isnt really that necessary in performance wise, but its good if you do it ;)Quote:
Originally Posted by bokis
230/600/800/1200 and polish
Yeah, polishing is just fun :D
Have the BT myself, and that stock fan barely moves ANYTHING. To get this sink to it's full potential you'd need a nice delta, or to strap another fan under it (oh, and it would probably fit too.
Originally Posted by Tulatin
50 cfm is nothing to sneeze at for the little noise it generates. I gained about 3 deg c at full load moving to a louder fan (78cfm).
50cfm and no noise is basically a silenX fan, so on the grounds of a noiseless cooler, it does well. I'm just a little leery to trust it to cool the componentry below when i can't feel the airflow out the other side (as compared to a much less dense sink the SI-97, which had tons of airflow out the other side with a silent cat attached)
I really like the BT and won't change, but I do use a secondary 50mm fan to cool the power area as the x2 proc REALLY sucks back the juice on high OC's..
looks like i'm gonna buy a BT :D
thank for the review
Where'd you get that nice "table"? Made it yourself?
"Roof" is 11mm MDF, did it my self :)
Hmm, turned over fan to suck through cooler but gained 3ÂșC higher temps in Prime95, OK, I had only 25mm spacer (from another "empty" 120mm fan)Quote:
Next week Thermaltake Big Tower with 120mm Enermax vs. Scythe Ninja SCNJ-1000 with 120mm Enermax, stay tuned :D :toast:
