i am always wonder that what is the full load temp on cascadaQuote:
Originally Posted by Dumo
idel and full load temp difference only 15C on DI
MickeyMouse
could u tell me where can get the black thing that cover outside of the mousepot?
mine is totally damaged............
NICE Score man. That's friggin FAST. Go for FOUR GHZ!!!! :slobber:
Even a suicide shot wld be well worth it.
So your saying, don't use thermal paste when using phase change? :confused:Quote:
Originally Posted by MickeyMouse
Denny,
Can you do me a huge favor and run 16M next time you have a chance to bench that beast around 3.8Ghz, please? I've been waiting very long time to see 9:00 in 16M on AMD and this might be that one chance :) Thanks a ton, man :up:
you would have done it with your rig if you had BH5 in there with that 10m run don't you thinkQuote:
Originally Posted by bachus_anonym
Very nice 32M with 57. congrats on WR.
More and more DI + 57's around here, nice competition. :)
Question: If you add, say, a copper mass between the evap and the IHS, wouldn't the larger mass of the cooling head be able to maintain a better load temp (at the cost of lower temps of course)? I agree that using a thinner/smaller contact area with the cooling head will utilize the freon/DI with more effeciency, but wouldn't a larger mass translate to less of a swing in loaded temps?Quote:
EDIT: Forgot to add - THAT'S ONE HELLUVA 32M RUN...wow 3840 :toast:
Don't forget me. :D
I can 3.7G 32M IHS on it.If remove :D
take it off^^ join with usQuote:
Originally Posted by AndreYang
Guess, here is my evap. temp(-84.7C) and core on bios(-27C).....I put a dry film (aluminium) thermal interface....
I still try to get -30ish core temp. so its mem. controller hopefully can run @ higher htt...
What is your temps ay that run?
i think you are totally right.Quote:
any mass reduces core temperatures imo...if there is -40°C left because of the layers between die and evap there is no need for cascades anymore - just use a weaker cooling unit e.g. single stage ^^
this way you will just try what's the lowest temp the unit will work properly.
my 3200+ winchester was unstable @-45°C and lowering the pressure, getting temps up to -30°C didn't help...back to air ~40°C 2750MHZ @1.61V no problem - damned cold bug :slapass:
my temp @ bios reads -33C @ 1.74vQuote:
and -45C @ 1.5v ^^
All I can say is...WOW :clap: As Jason said, these 32M WRs being broken left and right is for sure madness :D
Poor OPB, his record didn't last long.
I'm sure he'll be back with an answer.
Congrats on an amazing record, enjoy it. :toast:
Hey Denny,
I was curious what timings you were running on your memory. Got an A64 Tweaker shot? ;) The timings must have been insanely tight :toast:
I'd love to see what 3Dmark05 results you get with SLi 7800GTX's :slobber:
Is it 3D stable?
Nice one Guess ;)
yo're on a roll, man :toast:
imho if it compleats Spii32m then it will run 05 very easly.Quote:
Originally Posted by psy^
Awesome man! :D
nice run congrate on the WR
but i think OPB got answer to haha........
hehehe good for himQuote:
Originally Posted by z24
i want to earning more money...
might not do overclock anymore ^^
I'll bet you want more money after going thru 10 or so 57's ;)
@ Dumo, my BIOS temp is -26° under Baker Single stage, 3668mhz PI 1M stable.
hehehee actually i sold most of themQuote:
Originally Posted by G H Z
still wanna save more money, my wife wanna buy a house....
but i wanna buy a lot of CPU........... lolz
what is ur volt @ -26C?
my 57 pass 32m at 3840 but can't do 3850 1M XD
