Great to hear, but bad for me. Just RMA'd my TCCD plat. rev 2's like 2 weeks ago and got TCC5 back. Bummer. :(
~charlie
~charlie
Just some FYI: The TCC5 RMA's are being filled with existing RMA stock. So if you RMA with TCC5 you may get TCC5 back. Have no regrets as the TCC5 does just as well. :)
hi;
ocz platinum rev v1.0 or v1.1 which version is better ? I think v1.1 (tcc5) better than v1.0 ??
If you mean PC3200 Platinum Rev2 v1.0 or v1.1, they both do 2-2-2 timings at 200 and will run the same timings at higher speeds. Since they are on the bottom of the "food chain" so to speak, they likely will not clock as high as our PC4200 and PC4800 Platinum or 4800 Platinum Elite Edition products, due to the binning process.Quote:
Originally Posted by kosmonova
Predicting final speeds is impossible.
Hi Andy ,
Just bought a stick 3200 Rev2 to replace a defective Geil TCCD one.
Allow me to post some initial single channel results :
2-2-2-5 218Mhz 2,73vdimm link
2-3-2-5 not tested yet
2-3-3-5 245Mhz 2,73vdimm link
2,5-3-3-5 280Mhz 2,6vdimm link
2,5-3-3-5 293Mhz 2,73vdimm link
2,5-4-3-5 300Mhz 2,73vdimm link
2,5-4-3-5 315Mhz 2,73vdimm link
It's single channel but I'm really impressed... I'm running PC5000 speeds stable with this PC3200 Ram :slobber: Should be good for 300+Mhz in dual channel
Only problem now it doesn't play nice in dual channel mode ,together with my (working) Geil TCCD stick. The Geil TCCD needs 2,8+vdimm :slapass:
This one likes 2,6-2,73vdimm so it seems. Together it's BSOD galore
I guess I'll have to get me an OCZ platinum PC4800 stick to match this one :D The PC4800 platinum should be good for 300 2,5-3-3-5 and low vdimm , no?
Anyway , OCZ pc3200 REV2 is awesome stuff
Great results!Quote:
Originally Posted by Jaco
Always match your memory. If you get the PC4800, you might have an issue running the unmatched OCZ sticks. Get another PC3200 Rev 2 from the same store. ;)
thanks for the tip ,Andy.
I'll get another PC3200 rev2 stick , hopefully it's as good as this one.
