He must be busy with DFI crossfire...
Goddamit, can some MORE people post BEFORE and AFTER results please?
before = can't prime @ 2850mhz, after = I can prime all day long @ 2854mhz :banana:
which bios were you using before?Quote:
Originally Posted by Supertim0r
before voltage? after voltage? thanks.
Supertim0r
That's well within the margin of error. Ambients dropped 10C in the last month here in BC. If it was the same in QC, it could explain it ;)
Well I just flashed to the bios, and now my internet doesn't work. It says its connected, its sending fine, but nothing, and i mean ZERO, is being received. Worked fine before flash. Help?
is this bios labelled 704-2BTA.zip???
I ask because I downloaded 704-2BT days ago and now I have found 704-2BTA that should be latest BigToe revision...
can anyone confirm please?
thanx
You got it right :)Quote:
Originally Posted by arrarro
where's the link to the bios?
http://www.xtremesystems.org/forums/...67#post1035567Quote:
Originally Posted by JDizzle
Any recommended bios configuration to start with this new bios version?
I having some stability problems setting up this bios using my previous config
311HTT, 2800Mhz, 1:1 memory 2.5,4,8,4
askimo
The structure of the bios might have changed slightly, so you may have to set everything by hand again instead of loading a saved config
Flashed to this one the other night. Good stuff. Works great! :toast: :toast:
This is optimized for UTT like other -2 BIOS?
^ It very well may be....but it works great with my OCZ Plat Rev 2 1.1 which I *believe* are TCCD...they love low volts.
I just flashed from 704-2BT to BTA and so far I have gained 10 mhz on the cpu. I need to run Prime another 12 hrs but so far it looks good. Memory OC is the same.
Before 2850
Now 2860
voltage 1.58
30 Idle/38 Load
Originally Posted by Quest For Speed
all other settings the same? how about ambient temps?
thanks bigote
will give it a try tonight :toast:
All settings remained the same. Ambient temp over the last two days only varied by 1 ~2C and my load temps remained the same.Quote:
Originally Posted by chinkgai
nice!Quote:
maybe i'll give this a try...even tho chances are slim :toast:
this is only for bh5? why no -1 or -3 version?
didn't test ram-oc yet.
but i gained 10mhz on the core......maybe just the bad weather and the lower temps but maybe the bios :D
so far no problems.....i'll test ram another day!
mfg
My results in o/c haven't changed a single bit. the only thing that changed is my onboard lan doesn't work anymore.
rofl, i might have gained 11mhz more too on the core, not too sure about the ram yet at the moment...
priming at 8 hours now and still running where it would fail for sure after 1 hr before....
weather is a bit cooler tho... altho temps are nearly the same
will try more tnite!
oh, all settings the same
