-->The final cut!<--
(Remember a 70's song of Pink Floyd).. :D
When I returned home I thought to check again MSF3, MSF4, MSF5 and MSF6=2630 MHz (see table above) using 8M SuperPi (cos this table filled running 8M).
I did not check MSF7 cos this is the final step.
New MSFs were 1-3 MHz higher than before.
That's why I decided to bumped Vcore to maximum value via BIOS although stretching step by step is better but needs time.
I started at 2670 MHz the burn-in process (Lowest Priority, ZZZ=0, Threads=1).
After 30 minutes (CPU Stretcher was running) I tried 1M SuperPi and CPU passed it.
Immediately I tried 2M SuperPi but failed after 4 loops...
"I will retry 2M later" I thought...
Damn failed again...
http://www.xtremesystems.org/forums/...chmentid=36965
Jim Morisson said "People are strange" LOL I say "overclockers are crazy" :D
After 4 hours burn-in CPU passed 4M!
http://www.xtremesystems.org/forums/...chmentid=36966
But this does not mean that my CPU is SuperPi 8M/16M/32M stable there.
Is getting stable and I hope after some hours better results for 2670 MHz; why not for 2680 MHz?? etc..
After this I increased speed to 2680 MHz.
I did not run SuperPi immediately but after half hour...
Damn I tried 5 times and CPU could not pass 512K test!
http://www.xtremesystems.org/forums/...chmentid=36967
"Never mind" I thought burn-in will stretch you!
YEAH!
http://www.xtremesystems.org/forums/...chmentid=36968
Notes
1) When I tried for first time Vcore7=1.663 Volts LOL my CPU could not POST!
I turned off the mainboard and then OK.
2) My mainboard has a program for on the fly overclocking.
This program increases Vcore also but I have noticed instabilities sometimes (abnormal restarts or blue screens)..
That's why I prefer overclocking via BIOS.
But I will retry on the fly Vcore increases after a couple of days...
3) Most instabilities are when I increase FSB.
That's why I will run my PC at semi stable frequencies for soft applications (word processing/programming) and for 100% usage 50 mVolts more!
4) Although table shows from Vcore6 --> Vcore7 gain was only 20 MHz (see % loss is high) Vcore7=1.663 Volts will be for permanent usage cos I want 2650 MHz (or more) stable now. :)
