No probs solved my test #8 issues running memtest86+ right now at 11x274mhz 3-3-3-8 2T 8-18-2223 at 2.79v !
it takes 4ever to run std mode.....Quote:
Originally Posted by eva2000
44min still in #7...... but no error yet
funny you mention that as that's where i am first standard test pass test #7 17% mark 47+ mins :)
hehehehe, u know what, i got #8 error on 295 DDR590 2T
but the thing is that, if u check the "memory" show on memtest86+
only 3071M showing on the screen
and like test1 test2 are not smooth, it runs like 1% 2% then just jump to 100%. super wired!!!
one other thing! don't trust memtest86+ too much ^^
heh first post
To start with for 4GB, in DFI NF4 advance chipset bios section you need to enable PCI MMIO memory hole option to properly map 4GB otherwise you will only see 3GB of memory.
ops.... my bad~~ XDQuote:
ok i am going to switch it~~ XD
Eva, very impressive. Try stronger drive strength and longer max. async. latency and higher read preamble, these key settings are most important.
yeah with 623-3 bios, premable set at 6ns or higher = no pc boot even at stock speeds for 2x 1GB config for crucials and even for my 2x 512MB Centon PC3200LL TCCD tests as well... haven't tried a different bios since i swapped my SLI-D for UT SLI-DR board heh
Amazing stuff eva! Big props! :toast:
If I were you, I'd try different drive strengths, but other than that, you seem to be doing just fine. :clap:
Ok, its been 7 hours now George....... enough of the memtest !! :D
i just wonder..... do u guys really think that memtest86+ very important
or prime95 is more important
to me prime95 is much much more
I usually just use memtest86 to verify that the memory is stable enough to not corrupt windows, then I test in windows with memtest and Super PI. I usualy only use prime to test cpu but it works good for memory too.Quote:
Originally Posted by guess2098
memtest86 is definetly not the final word
yeah memtest86+ is important http://i4memory.com/showthread.php?t=327 :) but it's only part of the testing process
@11x274mhz 3-3-3-8 2T 8-18-2223 at 2.85v test #8 looped for 6+ hrs got 11 errors in total at pass #31 and 45 heh not
What kind of Sandra bandwidth scores are you getting at 274x11 2t with the 4 sticks ?
haven't loaded windows yet heh
set at 10x280mhz 3-3-3-8 2T in memtest so can test dimm stick config, swapped the 2 sticks on farthest from cpu socket around and got less errors related to 2100-2700MB range so right now config is
cpu socket
dimm 1 = L503 dual channel stick #2
dimm 2 = ZD2T single stick #3
dimm 3 = L503 dual channel stick #1
dimm 4 = ZD2T single stick #1
redoing 11x274mhz now
I didn't know you Aussies spoke Candian ? :DQuote:
Good luck, I'm just curious if you gain anything running 4 sticks in Sandra to make up for the 2t loss.
will do some benchies later today :)
also for guess2098, with prime vs memtest question, are you able to fully allocate all or most ram in blend mode ? as i can't get more than 1487MB of ram allocated http://www.xtremesystems.org/forums/...ad.php?t=73663
no probs once swapped sticks around the dimm slots
http://www.fileshosts.com/memory/cru...250_3338_1.jpg
http://www.fileshosts.com/memory/cru...38_test5_1.jpg
http://www.fileshosts.com/memory/cru...38_test8_1.jpg
cpuz http://valid.x86-secret.com/show_oc.php?id=37287
Just nasty 11x274mhz 3-3-3-8 2T at 2.85v :D
http://www.fileshosts.com/DFI/NF4_SL...erpi-1m_tn.jpg
http://www.fileshosts.com/DFI/NF4_SL...erpi-8m_tn.jpg
http://www.fileshosts.com/DFI/NF4_SL...rpi-16m_tn.jpg
http://www.fileshosts.com/DFI/NF4_SL...rpi-32m_tn.jpg
For Major, bandwidth ain't bad for 3-3-3-8 2T either
Everest 2.20.405
Read = 7,340
Write = 2,574
Latency = 45.1ns
Sandra 2005 Lite SR2a
Buffered = 6,417 / 6,434
Unbuffered = 3,007 / 3,043
Pcmark05 = 5,882
http://service.futuremark.com/compare?pcm05=95527
http://www.fileshosts.com/DFI/NF4_SL...82_4991_tn.jpg
Nice! very Nice! :toast:
Just one thing EVA off topic, you posted about prime and not getting it to
read or test 2 gigs fully, doesn't that mean 4gigs is out of the question and if
so, doesn't that make prime not a good benching program when 2 gigs or
better for overall stability?
:banana: HAha Eva, THANKS ! you simple killed my doubts !! Im going for 4x1 Ballistix Z503 for sure ! :banana:
Well did some more reading and partly it's to blame on winxp pro 32bit http://i4memory.com/showthread.php?t=1327 it only addresses per process 2GB max - i guess dual core cpus could fully test 4GB via 2x 2GB prime sessions then ?Quote:
Originally Posted by REBEL900
maybe /3GB switch will help with prime95 ?
guess means 4GB for winxp pro 32bit is really wasted heh better off with 2GB
Eva2000,
Are you running Bank Interleave on?
Care to peek what Sandra says about the Bank Interleave setting?
It's located in the Mainboard info-tab, iirc.
Which is it, 2-way or 4-way when all 4 sticks are installed? What about with 2 sticks?
yeah bank interleave enabled.. post #44 in this thread has my sandra screenies but doesn't mention 2 or 4 way heh :)
George, if it makes you feel any better I got bored tonight and tried my 4x1gig sticks in my game rig, DFI NF4 Ultra and X2 4600+. I could only get 272mhz stable with the 11x multi. So, once again.......its all in the memory controller ;)
