Just took a peek into their bios section and there is no NF4 section there yet. Although it does look like there is a space for it :)
I think you are thinking of the BFG board, not eVGA.Quote:
Originally Posted by dogsx2
http://www.hardocp.com/image.html?im...5fMV82X2wuanBn
Originally Posted by Major_A
http://www.xtremesystems.org/forums/...ad.php?t=71477
I think I am thinking of this thread.
Originally Posted by IvanAndreevich
Isn't this it?
http://www.jetway.com.tw/evisn/index.html
A03 (07/17/05) N89LGA03.BIN
(Asia Site2) Fix after S3 resume,CPU ratio& valtage return to default.Solution EPA logo add make hdd priority display error.Fix after S1 resume,Can't shutdown issue.K8 Rev:E6 support.(For 939GT4-SLI-G-EC/OC)
Did you flash with the jetway bios??Quote:
Originally Posted by highoctane
I also want to know this. If it works and sorts out the minor issues I may jump on a combo deal. :)Quote:
Originally Posted by Nettwerk
Screw it im gonna save the original to floppy and flash to the 939GT4-SLI-G-EC/OC bios after lunch.
That's the spirit! :)Quote:
I flashed the EVGA mobo to the 939GT4-SLI-G-EC/OC bios and it works great :) got rid of the annoying EVGA logo blocking out the boot sequence at the beginning too :D
Thank you very much! You've just essentailly solidified my purchasing decision. :)Quote:
Man those EVGA bundles are great. If I didn't have a DFI and a 7800GTX already, I'd get one right away ;)
Think I may get one next week.
anyone know what kind of caps it uses? good board, but if it uses low quality caps, longer reliability might be an issue with popping caps. Besides all those caps popping might be pretty annoying.
Look at the pics, looks very similar to the high-quality japanese caps DFI uses.
If you go past 250HTT 1:1 it wont save and will boot up at stock speeds. Tested GSKILL pc4400 and Mushkin XP4000.
What about clockgen?
Good question :)Quote:
ill try it
will it have the same problem using dividers?
Yup, I have gskill le in it right now and no matter WHAT setting I use/divider/blah it starts windows at default speeds. Its going to be the same with my mushkin XP4000 casue it acts just like this too. On to clockgen.. I bumped it up to 250x9 and it went then I tried 251x9 and it rebooted lol
Only thing I have that works on this mobo is 2x256 corsair LL 2-2-2-5 memory and mushkin redline 4000 but the redline needs 3.2 volts to even run stock speeds.
hmm have u tried different bioses?
heh theres only 1Quote:
Originally Posted by situman
New bioses should come out and hopefully fix this stuff
How high does vdimm go on this board?
3.25Quote:
Originally Posted by en4cer
What HTT multiplier are you using? If you're still at 5x (1000) then you are doing fantastic at 1250HT. I had to drop to 3X to make it above the 300 CPU Clock frequency.Quote:
For simple testing to see how far you can go, use a HT ratio that keeps the HT clock around 800-1100. That would be 4X above 230 or so, and about 3X above 260 to 270. You can tighten and tweak the HT frequency once you see where the board can go.
In my testing the Jetway board reset and recovered well from bad OCs, but it wasn't overly agressive on resets like some of the current Abit boards are.
