Athlon 64 3200+
DH8-E3
Max Tcase 55C
Best it can do is 2680 @ 1.6v :(
Athlon 64 3200+
DH8-E3
Max Tcase 55C
CPU Information (CPU #1):
Standard CPUID: Family: F, Model: 7, Stepping: 1
Extended CPUID: Family: F, Model: 27, Stepping: 1
CPUID String: 20F71
Processor APIC: 0
Processor: AMD Athlon 64 3700+ (San Diego)
Revision: SH8-E4
Platform: Socket 939
Startup VCore: 1.350v
Maximum Case Temperature = 65C
Written by: Arthur Liberman.
Contact me at: Arthur_Liberman@hotmail.com
Its a 0505FPMW ..
2830Mhz 1.35v stock air
2900Mhz 1.4v SLK900
2950Mhz 1.45v on Bigwater
3360Mhz 1.5v on phase
3400Mhz 1.55v on phase
3450Mhz 1.55-1.6v for bench
Phase change evap is -44c load
CPUID String: 20F71
Processor APIC: 0
Revision: SH8-E4
Startup VCore: 1.400v
Maximum Case Temperature = 59C
2920 mhz @ 1.52 volts
3ghz @ 1.60 volts
0515SPMW
Very Interesting. Most X2 3800's say 1.350v/63C MaxTCase. Mine says 1.300v/61C :
Standard CPUID: Family: F, Model: B, Stepping: 1
Extended CPUID: Family: F, Model: 2B, Stepping: 1
CPUID String: 20FB1
Processor APIC: 0
Processor: AMD Athlon 64 X2 3800+ (Manchester)
Revision: BH9-E4
Startup VCore: 1.300v
Maximum Case Temperature = 61C
Unfortunately my overclock is limited at the moment because of wonky DFI NF3 mobo which refuses to boot *any* chip above 250 HTT
:mad:
Weird, it must be in the stepping! Cuz mine is 61c VCore 1.3v hmmm.Quote:
Originally Posted by Pumbaa
The Mad Duke we have the same what is your stepping?
Mine is--CHBHE 0526UPBW
I am now stable at 2.9ghz at 1.58v but I am going to lower them and see how long I can run prime... I hit a wall cuz my PWMIC was getting way to hot. I put a fan on it and now no freezing or failures.
I edited my first post up there with more infos about it and no it's not 100% stable. 100% stable between 2925 and 2975 Mhz, Im running for my last wanted MHZs so I won't have to underclock my VX 500Mhz :p:Quote:
Originally Posted by The Coolest
**edited**
not stable @3Ghz but still SuperPi32M capable and 3D benchs.
PS: what's wrong with Superpi? I couln't resize the window to see the last line and the validation ID :confused: Max temp was 39C btw during test while browsing this forum :banana:
"Rev E Opterons, a sepcially Dual Opteron system.
These are the chips of interest! So please start contributing your results."
:fact:
http://img26.imageshack.us/img26/6160/tcase7ur.jpg
oh yeah...
2835 totally stable, 1.42v
2925 benches well, 1.55v
probably do a little more 24/7 but i try to keep temps below 45c on the chip, it has been up to 60c though.
Is there only one CPU in the system or are there two? The program should've been able to find two CPUs, but I see it only found one.Quote:
Originally Posted by drcrawn
If there are more than one CPU in the system, could you please download this, run it and hit F6 to make a register dump txt file, and then send it to me via email, or put it here on the forum?
Mine is a week younger. It's a CDBHE 0527TPBW. I'm testing to see how high the chip will go at stock volts (1.300v). So far it's Stress Prime stable at 2300.Quote:
Standard CPUID: Family: F, Model: F, Stepping: 0
Extended CPUID: Family: F, Model: 2F, Stepping: 0
CPUID String: 20FF0
Processor APIC: 0
Processor: AMD Athlon 64 3200+ (Venice)
Revision: DH8-E3
Maximum Case Temperature = 55C
does 270x10 fine @ 1.52v. haven't tried higher.
Mine stinks, but then again it's only able to do 2.4Ghz no matter what voltage I throw at it.
CPUID String: 20FF0
Processor APIC: 0
Revision: DH8-E3
Maximum Case Temperature = 53C
CPUID String: 20F71
Processor APIC: 0
Revision: SH8-E4
Maximum Case Temperature = 57C
CPUID String: 20FF0
Processor APIC: 0
Processor: AMD Athlon 64 3500+ (Venice)
Revision: DH8-E3
max so far 10x265, 1.575. boots 10x270 fine, will hard-lock randomly. crappy air cooling.
CPUID String: 20FF0
Processor APIC: 0
Processor: AMD Athlon 64 3000+ (Venice)
Revision: DH8-E3
chip in sig, does:
2.63 stock volts air
2.72 1.42 volts air
2.81 1.53 volts air
2.86 1.58 volts air
2.95 1.65 volts water
3.00 1.73 volts water
CPUID String: 20F71
Processor APIC: 0
Processor: AMD Athlon 64 4000+ (San Diego)
Revision: SH8-E4
couldnt' get it stable at anything more than 2.6 Ghz with voltage up to around 1.6v :(
Hi, sorry this is on a single cpu motherboardQuote:
2875mhz @1.60v 32M stable, Prime95 blend stable for about 1.5 hours now...
temps is 46c on water, ambiant is 25c.
Currently running 3000 winnie 2.6ghz@1.485v. Max at 2.7ghz@1.61v.
CPUID String: 20FF0
Processor APIC: 0
Revision: DH8-E3
Doing 304x9 @ 1.4 vcore ;) (prime stable)
How come same family cpus, for example, 3700+/4000+ SD have different case temps?
Processor: AMD Athlon 64 FX-55 (San Diego)
Revision: SH8-E4
if this is any help: my D0 Palermo can run at 80 degrees Celcius and still be 100% stable... with a 45% OC
Yes and why does madpete's FX-55 have quite a low case temp. Surely fx chips are speed binned to be the best clockers.Quote:
CPUID String: 20FF0
Processor APIC: 0
Revision: DH8-E3
2805.3 MHz - 1,45Vcore
CPUID String: 20F71
Processor APIC: 0
Revision: SH8-E4
