:D I will take screen 4.2ghz tomorrow.
New SS seam right. I reach 4.06ghz but ram slower because dont have enough power.
impressive... wonder what crunching with dual "dual core xeons" will be like...
very sweet indeed.
bump! any update?
What type of Air Cooling are you using?
I am very intrested in Getting a Pentium D and Overclocking but am worried about heat. We all know Prescotts like to get hot. And now we have 2 of them super glued together.
Very impressive, especially since it's on air.
Hyper 48 man. temp are good around 5x oC. Sory i dont have time to update till this weekend.Quote:
Originally Posted by Puni Puni Poemy
Originally Posted by FUGGER
Could you test one under the cascade? :)
Jan, yep. I will retry with the 830 under cascade.
I have a few builds this week and a few P5WD2's to test oc with. I plan to rip a PCM2K5 above 5Ghz, cant guess how much above yet but the three stage should do good with the 820/830. My 840EE runs hotter.
Thanks. Thats great! :)
im playing around with a 830 ,seems stable so far at 4.6 . i was wondering ,is their a throttle watcht verstion which is compatable with 2 cores. dont seem to get the throttle screen up , with the verstion i have, another ting is pcmark o5 . the test runs fine,but cant get a totall score? lots off them come as n/a , ayone know off this? bug? got 84836 in aquamark . 3dmark o1 is like 3000 slower then with the 640 and samme ghz? wierd. maybe i should reinstall the gfx drivers? by the way . the 830 could do 4,0ghz on auto vcore :D god dam big intel køler they send with this beast . im running it on ls.
Congradulations with your 830 vanovich ;)
Hoping to see some ownage scores from you ;)
BTW what are temp on the Ls display and speedfan/whatever you use ;)
temps on ls are -38 idle -29 load on ls display .Quote:
Originally Posted by Nosfer@tu
Smae here at 260 fsb x 19 and 1.525 vcore.Quote:
Originally Posted by vanovich
Just cant geet the sucker stabil :(
