Did you check to see if your fan speed settings were the same in the BIOS?Quote:
I flashed to 704-3 on both of my DFI NF4 without any issues.
The download links on your site are down.Quote:
Originally Posted by NiCKE^
I flashed and it wouldn't POST at first either. CLeared CMOS and then it posted. I already don't like it because of that. Probably going to flash back myself.Quote:
Originally Posted by smids
Flashed with 704-3. I also had to clear CMOS after that. But it's working great, as good as any other BIOS (at least to me). Sometimes I have to clear CMOS after applying Optimized Defaults (it dies after it's done) but this was happening on many BIOSes before. No biggie, although I would like to see that fixed, please ;)
Thanks Oscar and WWM for sharing :toast:
EDIT: Actually, now I remember that I did not clear CMOS but only hit RESET and it woke up :D Same for Optimized Defaults deal :D
I was in the middle of testing the 702-2 but decided to jump to the 704-2 bios.. Im running 4x512mb TCC5's in my rig at 264x11 2.5-4-8-3 2T totally stable.. Of course 2t isnt good for benching, but using that and 2gig's just kicks BF2's a$$..hehe..
:banana:
I think I am going to give this a try right now.
burninggrave i have the same seeting and in full i give 51º and with 618 have 46
at last hare 5º up
Glad it wasn't just me who went through the Clear CMOS thing to get it working. Perhaps it just depends on which BIOS you flashed from. I flashed from 623-2 to 704-2. I've done a reflash since which worked fine but obviously it was only writing over the same code.
Hmmm still down, anyone with another linky ??Quote:
Originally Posted by burningrave101
Originally Posted by alpha0ne
http://www.techpowerup.com/articles/other/114
The same happened here. Chipset temp was C42-43 with 623-2 (my computer had been on for 12 hours+). Then I flashed to 704-1 and now it shows C49-50 with same settings.Quote:
IMO it depends on the total clock and your DRAM setting, especially on twtr,trrd,trtw etc..Quote:
Originally Posted by mcnbns
this is mine
512x2
devider 166 , 306x9
2-2-2-5-7-15-0-2-2-1-3120-1
250mhz = 3363 MB/s :toast:
Thanks m8 your da man :toast:Quote:
Originally Posted by Fosco
no problem with this bios either....didn't need to clear cmos, though it hang on verifying DMI screen, had to go back to BIOS and save the setting again...then boot right in to Windows and so far my rig is still prime95 stable :D :D
Finally! :)Quote:
Originally Posted by windwithme
Try usb keyboard with ps2 mouse. That was the fix.Quote:
This bios seems to be working just fine.. I raised my HTT to 330 and ran Prime95 all night. HTT 330 was not stable before this bios. I havent changed anything else but the bios and the HTT to 330. I am going to shoot for HTT 335 tonight and we will see how it goes. I did notice that when I went to HTT 330 that my temps only went up to 35c but before I changed my HTT the temps stayed the same. Great job guys!!!
I think a bit MORE stability for me. ~10 Mhz on the RAM? Not nearly done testing.
I have never understood how people can gain more oc on their memory from a bios change. I myself have never had even 1mhz more on my memory from any bios on any board I have ever had. Baffles me really.
fx (0.13) are get low score at memtest, and i mean very low :DQuote:
not as stable for me
I have a noob question : How works Bank Interleave ??Quote:
Originally Posted by eva2000
http://www.dfi-street.com/forum/showthread.php?t=11397Quote:
Originally Posted by xs64
DRAM Bank Interleave
Settings = Enable, Disable
Paraphrased from Adrian Wong’s site: http://www.rojakpot.com/
”This BIOS feature enables you to set the interleave mode of the SDRAM interface. Interleaving allows banks of SDRAM to alternate their refresh and access cycles. One bank will undergo its refresh cycle while another is being accessed. This improves memory performance by masking the refresh cycles of each memory bank. A close examination will reveal that since the refresh cycles of all the memory banks are staggered, this produces a kind of pipelining effect. However, bank interleaving only works if the addresses requested consecutively are not in the same bank. If they are in the same memory bank, then the data transactions behave as if the banks were not interleaved. The processor will have to wait until the first data transaction clears and that memory bank refreshes before it can send another address to that bank. All current SDRAM modules support bank interleaving. It is recommended to enable this feature whenever possible.”
Large Influence on Bandwidth/Stability
Suggested Settings for DFI: Set to Enable whenever possible----it is a fairly influential setting for improving bandwidth. Disable for stability and a corresponding loss in bandwidth. (Enable = Faster)
Big thx , man :toast:Quote:
Originally Posted by stealth17
Bios 702-2 and 704-2 , my BH5 is hard to stable at 270 @ 3.6v :( , higher vol doesn't help :slapass:
