Are you joking me. The amd stock heatsink comes with copper heatpipes.
yes, and a copper bottom.
http://www.prodigyweb.net.mx/goyomor.../FX-55_HSF.jpgQuote:
Originally Posted by elec999
Very nice. I doubt single spi 32m is even considered mark of stability for those asking stable to be honest for those people asking. Only way to make sure is test prime 95 on both core together (or if you don't like the heat factor, individual core) and find out what is the GCD. I think he might be one of the first person to have both cores doing well.... in my case, one core does significantly better than the other core for 2 of my CPU. (as well as reports of most X2 users in forum)
On vapo it would be harder to tell though. maybe he will do the compare test.Quote:
Originally Posted by jinu117
AndreYang Great overclock! Have you tried to see if the overclocks are stable with 2 benchmarking programs running?
From what i've seen elsewhere if only 1 is running only cpu 0 is beenig stretched, but that doesn't mean that cpu 1 will take the same oc. So to verify oc stability one should probably run something like 2 super pi processes (from 2 super pi installations otherwise the processes will try to write on the same file) or say 1 super pi and 1 pcmark process running at the same time.
Originally Posted by skipio
I need to wait to holiday for test. I am busy now.
I will run 2*Prime95 and some test on the weekend.
Oh, trust me, BOTH cpu's are good:Quote:
http://www.ocxtreme.org/onepagebook/...bench64bit.jpg
Originally Posted by s7e9h3n
hmm......your OS is WinXP 64bit
I use Win XP 32bit.............
s7e9h3n XXX i p LOL pron star now? some competition to opb xD rofl
Hehehe...that shot is from OPB...I sold him the cpu ;) I guess I could always show his 10K pcmark 04 shot, if there's still any qeustion to the quality of the cpu :p:Quote:
Originally Posted by leviathan18
BTW, here's the "bad" 4600+ I had for comparison's sake ;) This was done on a stock mach2 by me :p: :
http://img87.echo.cx/img87/1917/11x288sandracpu8gl.jpg
damn! almost as much as 4 Opterons? I WANT ONE NOW!
4200+ starting to crank it right now this is it's 3rd boot
Here's 275HTT 9:10 Mem Ratio
It's really starting to come alive at these speeds.
http://img52.echo.cx/img52/8373/275htt9104nb.th.jpg
:toast: awesome testing!! ur a64 x2 skew my xeon.... :mad:
that is the most awesome cpu i have ever seen.
very impressive overclock. my x2 is arriving today if everything is ok. hopefully have some benches soon :).
mine should be here tomorow with anyluck... see how they do on water
The X2 are having impressive overclocks. Anyone ever try a dual-stager on them yet? I wonder if they have the cold bug.
very nice man... that's awesome that it came with a decent hs with heatpipes
Excellent work!
Next week i think i receive my 4800+ here in store...
That´s greatfull CPU!.... :slobber: :slobber:
2.7G , 1.36V , 2*SP2004 1 hour
http://myweb.hinet.net/home2/andreyang/Air4800/4.JPG
2.8G , 1.39V , 2*SP2004 1 hour
http://myweb.hinet.net/home2/andreyang/Air4800/7.JPG
http://home.comcast.net/~kjboughton/30.6.JPG
http://home.comcast.net/~kjboughton/cache.JPG
http://home.comcast.net/~kjboughton/cpu.JPG
http://home.comcast.net/~kjboughton/mm.JPG
Beaten by dual Xeons! You definately have the advantage with memory BW but you don't want to see the cache results. The 2MB L3 in each Gallatin mops the floor with your X2.
:toast:
-FCG
Yeah, but you had to buy two CPUs and a special mobo, and X2 would win in gaming benchmarks too...Quote:
Originally Posted by freecableguy
I guess it depends on what you use your comp for. :)
