"might go off a bit" is putting it mildly :lol:
--- Chad --- Vtt is used by the memory and the CPU as a reference signal to tell when a signal is high or low. It's also used in the termination networks for the signals on the MB to...errrmmm...in "gumbie" as you put it... to make the signals better. What I was telling Malves is that under certain conditions the Vtt fluctuates a lot causing errors. What he was saying is he doesn't have a CPU to put in the MB to check out what I told him.
--- Malves --- Vtt is rock solid stable until certain burst data patterns are used... then it fluctuates quite a bit... enough to cause ~25Mhz OC difference :( It appears to be a load issue, as it's relatively long term fluctuations (you can see them with a DMM). You can run T5 (pretty much T1->T7) and it's rock stable... T8 and it's all over the place during the course of the test. You can pretty much predict when errors will pop up by monitoring where Vtt is. Same thing happens when in Windows... and when running most benchies. Note that both the input rail and the reference to the VTT regulator remain rock solid... it's only the VTT output of the regulator that fluctuates.
Peace :toast:
