in five minutes we will know the truth :woot:
cant wait
K HERE WE GO
this is the dry ice we got, 20 kg of pellets:
http://j0rt.zattevrienden.be/jort/do...i-DSC05993.JPG
now some random pics taken during the run:) i'll comment if info is needed with pics.
http://j0rt.zattevrienden.be/jort/do...i-DSC05994.JPG
board with mods:
http://j0rt.zattevrienden.be/jort/do...i-DSC05996.JPG
max temp dry ice:
http://j0rt.zattevrienden.be/jort/do...i-DSC05997.JPG
the adaptor with dothan cpu:
http://j0rt.zattevrienden.be/jort/do...i-DSC05998.JPG
adaptor installed and covered with grease(vasiline):
http://j0rt.zattevrienden.be/jort/do...i-DSC05999.JPG
shot of thermal grease dothan core:
http://j0rt.zattevrienden.be/jort/do...i-DSC06000.JPG
container installed with mounting of alz his waterblock, i tell you its VERY easy to use:
http://j0rt.zattevrienden.be/jort/do...i-DSC06001.JPG
first the best card offcourse, its an TNT2 used to be a very good card :D
http://j0rt.zattevrienden.be/jort/do...i-DSC06002.JPG
setup installed:
http://j0rt.zattevrienden.be/jort/do...i-DSC06003.JPG
http://j0rt.zattevrienden.be/jort/do...i-DSC06011.JPG
http://j0rt.zattevrienden.be/jort/do...i-DSC06013.JPG
http://j0rt.zattevrienden.be/jort/do...i-DSC06015.JPG
container with dry ice;)
http://j0rt.zattevrienden.be/jort/do...i-DSC06016.JPG
3160 mhz superpi run, result is 23.766 :woot:
http://img260.echo.cx/img260/8301/23s7xg.jpg
http://j0rt.zattevrienden.be/jort/do...i-DSC06032.JPG
http://j0rt.zattevrienden.be/jort/do...i-DSC06031.JPG
left = base | right = direct into container(watch this screen again a bit lower)
http://j0rt.zattevrienden.be/jort/do...i-DSC06034.JPG
temps realy stay within 1° !!! (this isn't the screen i mean)
http://j0rt.zattevrienden.be/jort/do...i-DSC06026.JPG
LOOK after 5 hours later the temps got to -66 on this screen and -65 on boot and -64 stressed. so the thermal grease settled and got 4° better :banana:
http://j0rt.zattevrienden.be/jort/do...i-DSC06052.JPG
then we throwed an R9700 pro into the game, purpose to brake mister roadster world record(allready took 1 record of him with 3000+ spaw:D)
http://j0rt.zattevrienden.be/jort/do...i-DSC06045.JPG
http://j0rt.zattevrienden.be/jort/do...i-DSC06046.JPG
but the card wouldn't boot:( (now kristos arrived by now so we plugged into the x800 and explore his max speeds on air back,
when is installed the zalman aircooler back onto the R9700 i saw that the 4 pins connector whas not installed propperly "damn alz" :stick:guess its for next time.
removed the box with dry ice of the tabel couse its was getting wet underneath, yeah its cold allright :D
http://j0rt.zattevrienden.be/jort/do...i-DSC06048.JPG
alz is trying to get his hands frosted or trying to be cool :p
http://j0rt.zattevrienden.be/jort/do...i-DSC06051.JPG
keep the container topped :)
http://j0rt.zattevrienden.be/jort/do...i-DSC06054.JPG
rig with aircooled X800xtpe
http://j0rt.zattevrienden.be/jort/do...i-DSC06060.JPG
offcourse with overclocking you get thins like BLUEscreen ^^
http://j0rt.zattevrienden.be/jort/do...i-DSC06056.JPG
and some complaining about drivers not installed :p
http://j0rt.zattevrienden.be/jort/do...i-DSC06057.JPG
silent air cooling:
http://j0rt.zattevrienden.be/jort/do...i-DSC06062.JPG
now we tried to do some aquamark score's and yes the yes yes yes NO whas there:) but we got 100K afterall YEAH
http://j0rt.zattevrienden.be/jort/do...i-DSC06067.JPG
17K raw cpu dothan power!!! don't think these where the gfx settings but 3117mhz dothan was always used while benching:)
http://j0rt.zattevrienden.be/jort/do...i-DSC06070.JPG
offcourse we did some 3dmark 2k1 and got till 38800 but then something stranged was happening, wile oc'ing the card to 642 610 and ran 2k1 the clocks where reset to 549 without a reason because everything was stable:(
http://j0rt.zattevrienden.be/jort/do...i-DSC06071.JPG
ohhh -64 :slobber:
http://j0rt.zattevrienden.be/jort/do...i-DSC06075.JPG
-52 @ 644 mhz:D
http://j0rt.zattevrienden.be/jort/do...i-DSC06083.JPG
we got 100K, 101K, 102K, 103K, 104K and finaly 105K! after lots of runs and reboots:)
compare
http://j0rt.zattevrienden.be/jort/do...i-DSC06082.JPG
then offcourse this happend too:slap:
http://j0rt.zattevrienden.be/jort/do...i-DSC06086.JPG
zalman bracket, container, silan wrap kept the card running:
http://j0rt.zattevrienden.be/jort/do...i-DSC06087.JPG
Disassambling of the system:)
no air no condensation had any chance here:
http://j0rt.zattevrienden.be/jort/do...i-DSC06088.JPG
http://j0rt.zattevrienden.be/jort/do...i-DSC06089.JPG
after 9 hours of running dry ice almost no condensation has formed
http://j0rt.zattevrienden.be/jort/do...i-DSC06090.JPG
little sweat on backsite but who wouldn't sweat with these conditions
http://j0rt.zattevrienden.be/jort/do...i-DSC06094.JPG
PERFECT contact and NO condensating
http://j0rt.zattevrienden.be/jort/do...i-DSC06095.JPG
alz has some job with removing the grease:D
http://j0rt.zattevrienden.be/jort/do...i-DSC06096.JPG
http://j0rt.zattevrienden.be/jort/do...i-DSC06097.JPG
the drip was from the container:)
http://j0rt.zattevrienden.be/jort/do...i-DSC06098.JPG
alz realy did some SUPERB insulating job!!!
http://j0rt.zattevrienden.be/jort/do...i-DSC06099.JPG
and some FINE soldering work, this is realy good
http://j0rt.zattevrienden.be/jort/do...i-DSC06100.JPG
http://j0rt.zattevrienden.be/jort/do...i-DSC06101.JPG
This was a superb succes, nothing died everything was running like it should.
K the x800 could be better but there is a big change that next week alz can use his ex x800pro xtpe back to use, it did 675 675 on water and fully vmodded offcourse:) so 725 or 750 wouldn't be that hard on that one.
I like to thank to browse to all the pic and thanks colin and kristos and me to be a perfect team :)
till the next time;)
over and out,
Jort
nice work, nice pics!!!
GREAT JOB!!!
tnx, like to keep the community up to date with loads of pics:D
we learned again big time from this run :)
next run i'll do with another friend is X2 4200+ and dry ice,FX-57 on dice. gfx not known yet:)
Jort, don't forget i used only a waterchiller for 3405Mhz with SPAW :p:
Good luck for the nexts runs. ;)
Very nice runs Jort :toast: Lookin forward to seeing how the X2 and FX-57 do. :)
Great job! Nice days work!
Great job guys, congrats :toast:
Great pics man, those are classic with the magic bean pellets. Also reminds me to grease up my mobo when I put the cascade on it.
Yeah very nice pics of how to properly insulate a dothan under dice :)
only 3100mhz... :( i expected 3300 from dry ice!
you expect too mutch then :p:
3300 mhz is capable but not with dice:)
so where going to meat again with some liquid stuff:D
well, i have seen 3100-3200 with phase change(single stage not cascade...) and i expected something like 3200-3300 with dry ice!
kingpin on ln²and its a 760, alz has an 730
=>http://pic8.picturetrail.com/VOL256/...6/96933517.jpg
just have to be lucky with the cpu :)
next time if u need my x800pro u call me ;) .
nice scores i hope u du more benching tis summer :banana:
x800 is ok.
I had some probs with it yesterday: I had tearing in games and stripes at boot up and in windows.
my voltmeter displayed insane core voltage and major fluctuations. even when I turned down the VR completely it still was at 1.6V but my meter was also low battery so I placed the card in the oven for a couple of hours and replaced the battery in the meter and everything is fine now :) :woot:
Great pics. Very well done.
Nice... did you run 3dmark 05 ? :slobber:
No, we didn't have any time left and it wouldn't be such a good score because the x800 didn't clocked that high.
just wait till beginning next week, alz85 is going to do another run with his ex-x800xtpe that did 675 675 on water and memsinks
Impressive.
Man, you guys deserve this credit! That mounting was amazing, not to mention running it for 9 hours straight without any major problems (i.e. things dying, bsods and resets don't count :))
Congratulations, extremely well documented, I enjoyed viewing this :)
Good luck taking Misterroadster down :D
:toast:
ah btw there is an article comming from this run :)
Very well done guys!
This is XS at its best :D
Truly extreme, no puny little XP120's or water cooling :wasntme:
You forgot we wanted to but the .exe was corrupted so we couldn't install it ^^Quote:
Originally Posted by Jort
