Thanks so much Charlie, Sampsa & other XS members for your trust on members of Team Japan :toast:
Also, cpulloverclock to report initially our activities in
here in XS with many tks ;)
BTW, there are some certain rules/restrictions although unspoken but which are well respected by Team Japan members for running SuperPI as follows:
1. You may disable some OS services,
2. You may adjust size of pagefile,
3. You may use memory tweaks such as setting by maxmem or A64Tweaker,
4. You may adjust L2 Cache size in registry,
5. You may set Priority in Processes at your option,
6. How you format & partition HDD is up t:wave:o your option.
It is quite arguable what tweaks would be acceptable but these are the rules atm after a quite bitter arguments or battles you might say at Team Japan when one of extreme OCer came up with his tweaks to end up 0(ZERO) second on SuperPI 1M in the past.
But, trust or not trust is all up to your discreation ;)
Cheers
