Using 618-3, this one is better than all previous bios for me.
Onepagebook
You got some specific numbers? :)
yea, everyone says better but define better. I have never in all my life been able to get a higher fsb out of a bios than a previous bios. My system performs the same on 510-2 bios as it did on 1/25. No worse but certainly no better.
btw what is SLI broadcast aperture in the newer bioses?
looks good? :p:Quote:
Originally Posted by IvanAndreevich
http://img44.echo.cx/img44/2734/275gq1m9ab.jpg
http://img92.echo.cx/img92/3104/0513mpmw0mw.jpg
forgot to set trcd as 3 :p:
http://www.ocxtreme.org/onepagebook/.../3489pi32m.jpg
what makes it better? higher fsb/htt, higher stable cpu, runs cooler? what?Quote:
Originally Posted by Onepagebook
Of course that looks good ;) BUT what did it look on the previous bios is the question
OPB. Can you every ask Oskar if he plans on putting video card overclocking into the DFI Bioses? MSI and Gigabyte both have this option in their NF4 boards and I think it is a really great idea. People are having great results with it and it seems more stable than software versions in windows plus no additional software needed to be installed to overclock your video card if it can be done via the bios. I'm sure Oskar with his talent can pull this off and would be quite an addition to the DFI boards.
Originally Posted by cantankerous
I asked that before NF4 series hit the retail, but I think Oskar has it's concern.
The hard part is there is no more space can put it in there with memtest86+ already there.
you're right except runs cooler. :)Quote:
Originally Posted by HousERaT
OK that's a little more clear. Do you have any numbers? Like what was the best before you used the 618-3 and what have you gotten since changing?Quote:
Hummm
Let's try...
I flashed back 618-3 and it works now , but the Vdimm measured by multimeter always over 0.1v than Vdimm in Bios setting ??? ( with all bios )
Flashed it. 3'2V+0'3Enabled gives me 3'08V and fluctuates to 3'18V (that didn't happended if I remember correctly). And it detects me 1023MB not 1024 now :?
Still at 236 1'5-2-2, 239 isn't stable like before (with jumper to 3'3V)
better?Quote:
and u posted that
I dont believe it's possible at 2800, especially with XP SP2 and these timings
28.234 it's the best time at 280 1:1 1.5-7-12-2-2-2 Win2k3
http://www.ocxtreme.org/onepagebook/...bn/28gpi1m.jpg
others Japanese think the same thing :)
I'm waiting ur response impatiently :p:
:D Stayed a long time with 331-1. Working fine with BH-5 (max. 283 at 3,72 Vdimm) but when I got my X850XT I had a start up issues. BIOS recognized the card only when hitting the reset button.
Flashed to 615 and the issue disappeared, working fine and stable with my previous settings like shown in SIG.
Though I use PS/2 for mouse & KB i copied some pics from digi cam via USB and it worked fine for me.
:toast:
Hmmm ok, well thanks for looking into it. I am a little dissapointed I guess as I think this would be a really neat feature. I guess you can't have it all :rolleyes: . Hopefully something can be done in the future.Quote:
Did anyone notice that the 32byte Granularity setting went from (disabled 8 bursts) to (disabled 4 bursts) and from (enabled 4 bursts) to (enabled 2 bursts)?
Wonder if this affects performance...
Just flashed to this bios. No problem whatsoever yet no visible improvements yet either.
Works good with 2GB ram also :)
Any success on the cold boot problem with this BIOS?
I think these are the best BIOS yet. I am using 0618-2 with Gold BH and saw increased stability and OC. My previous best 32M run was 2815Mhz, now I can run 2840Mhz for the first time (I have run 3 32M so far). I can't wait to try out 0618-3 tomorrow with my TCC5. :D
Great work Oskar! :toast:
http://members.shaw.ca/Eldonko/258x11-1.JPG
I think most would prefer GPU OCing stuff over memtest in BIOS, I still use a floppy for memtest myself.Quote:
This is the best bios for me too.
This is not "a little" better than the other ones, this is VERY MUCH better. With other BIOSes, when I tried to pass memtest86 test5 with 2.5 3-3-6 I got around one or two thousands of errors, with this BIOS, I got less than a hundred.
Hope the next BIOSes can help me making my G.Skill's stable at 300 2.5 3-3 :D
Thank ya'
Everything WORKS!!! Yeahhhh!!! Finally. USB mouse works, usb keyboard works, ps2 works, and clocks are still great. Thanks Oscar. (618-3)
Seems like this is a killer bios, my cpu seems stable at 2,7ghz !!!
