it has some 3,6ns mem so that sounds quite good :)Quote:
Cogn Bro :woot:
Could you help me İD moding my Leadtek A6200TD please...
http://www.xtremesystems.org/forums/...id=33038&stc=1
But Futuremark dosent see my card as 6600GT :confused:
ORB says 6200 :(
Have you tried IDing it as a vanilla 6600? That's what I had to do with my 6200 and it showed up as a 6600 in everything just fine.
i tryied as a 6600 But it didnt work again... Could Someone Tell me What should i do exactly from the bigining ?Quote:
Originally Posted by JasonE4
http://www.xtremesystems.org/forums/...id=33044&stc=1
I'm pretty sure that you have to check the box to "Allow enabling hardware masked units". Also, you must restart after changing the ID. You'll probably have to reinstall the video drivers after restarting as well.
1- First i removed Driver
2- then i selected Settings like this And accepted them
http://www.xtremesystems.org/forums/...id=33045&stc=1
3- i restarted My Comp
4- then i Setup Driver...
5- Restart again
6- i get sad when i see 6200 again :confused:
My asus 6200 will be here today :banana: :banana: :banana:
hope u have some fun whit it el snorro ;)
Originally Posted by Troman
Do you have another name on this forum? maybe Geforce4Ti4200? :p:
^lol
Now that you mention it, I haven't seen him around here in a while.
damn my 2nd pipeline unit is broken :mad:
when i set it to 8x1,3 it artifacts (not really big, but the are there) in aquamark and 3mark.
Are there more people who's pipes were broken??
I just hate this :mad:
Yes, there have been a few people who have been unable to open the disabled pipe.
Well i'm not unable to open it, its just broken.Quote:
Maybe an other bios will fix this?
I'm gonna try that. :dammit:
do thisQuote:
Originally Posted by cmanisali2001
1-install the drivers for 6200
2-restart
3-select in riva rhe 6600GT
4-then restart
5-and then u should get "New Hardware found"
6-and then install the drivers again
7-and restart
8-and finally it should be 6600GT
Unlikely. By "unable to open it", I mean, "unable to open it without artifacting". Let us know if the bios flash worked.Quote:
Originally Posted by El Snorro
Thanks a lot my Friend but...Quote:
Originally Posted by hwgeek
İ did what you exaclty said.. but it didn't work...
which version of rivatuner did you used ?
i used v2.0 RC 15.5 ...
And What did you exactly did on riva tuner ?
http://img83.echo.cx/img83/9889/ss5rt.jpg
