oh yea 600/1350 sounds rite for unmodded card. :D
rip off a Aquamark bench if you would please
My congratulations, misteroadster ! Impressive score you have there, aircooling days are over for us, i guess we need to move to something better :D.
:toast:
just a little improvement :rolleyes:
http://service.futuremark.com/compare?2k1=8590015
Yes that's the GPU voltage mod ... i've removed the SMD resistor and replaced it with a 1K pot, now the adjustment is more linear and exact.
Ncie scoreing Misterroadster ! :toast:
Regards
Andy
So, the higher resistance the more volts? or the lower the more volts?
Also, that second wire soldered to the voltage monitoring spot, is that just an extension for easier reading?
Also, the mod is just from 1 side of that chip, to the other side right? (just makin sure)
Pc Ice ... so is that like just adding a 10K VR then?
Thx zakelwe :toast:
Oh yea.. :D Well done m8, misteroadster settting some good targets for US :p
